Author Topic: Kawasaki GPZ1100  (Read 8789 times)
Offline dhall57
Kawasaki GPZ1100
« on: June 09, 2016, 03:13:56 AM »
Anybody ever have one of these or know much about them. Aren't they fuel injected.
1970 CB750KO
1971 CB500KO-project bike
1973 CB350G- project bike
1974 CB750K4-project bike
1974 CB750K4
1976 CB750K6
1977 GL1000
1997 Harley Wideglide
Online Stev-o
Re: Kawasaki GPZ1100
« Reply #1 on: June 09, 2016, 03:31:20 PM »
I have the little brother, the GPz 550... great bikes!  The 550 is pretty quick, cant imagine how fast the 1100 is, I would prolly hurt myself.
Yes, the 1100 is FI, 550 is not.
My 550....
« Reply #2 on: June 10, 2016, 06:32:22 AM »
The engine is the last of the breed and is very tough. Best head, crank etc. Fuel injection is early....I knew several guys that switched over to carbs after running into injection problems. Other fella's never had a problem with the injection.
Offline JamesH
« Reply #3 on: June 10, 2016, 08:03:52 AM »
Early primitive Fi system was prone to failure. Biggest issue was degradation of the electrical connectors, causing high impedance and resulting in the FI mis-calculating fuelling quantity / timing. Other than that, great machines.
Offline dhall57
« Reply #4 on: June 11, 2016, 02:16:11 AM »
Sounds like I better just stick with CB750's James ;)
1970 CB750KO
1974 CB750K4
1976 CB750K6
1977 GL1000
Offline Leino
  • Not much of an
  • in drag racing since 2005
« Reply #5 on: June 11, 2016, 03:50:00 AM »
Nice bikes, last great Kawasaki engine in my books.
Offline dragracer
  • CB750F Dragbike
« Reply #6 on: June 16, 2016, 11:03:12 AM »
Great bikes. We use the heads and transmissions in our drag bikes because they are better/stronger than any other KZ/Z1/J model produced. Also the cranks are stronger. And hey, those bikes just look darn nice when restored.
Offline 01Thomas
« Reply #7 on: July 08, 2016, 01:54:16 PM »
I have that motor in my Bimota KB-3. It's now running a Wiseco 1170cc kit and Mikuni VM-33 smoothbores.
1971 Honda CB750 Four K1 [Engine: CB750E-1113521 / Frame: CB750-1113838]
1977 Seeley Honda CB750F (F1) [Engine: CB750E-2551214 / Frame No: SH7-655F]
'96 Yamaha YZF750SP & '81 Moto Guzzi SP1000 & '80 Moto Guzzi 850 LeMans II & '82 Bimota KB-3 [Frame No 49] & '66 Ducati 50 SL/1 & '53 Miele K-50 & '38 Miele 98
« Reply #8 on: July 08, 2016, 04:23:06 PM »
They come in 2 models, the B1 and B2, the B2 has improvements and is a better bike, the fuel injection is hit and miss, most junk it for a good set of Carbs....
https://www.z-power.co.uk/merchantmanager/view_information.php?pId=35
Read below the model section for more info.... ;)
Offline grcamna2
« Reply #9 on: July 08, 2016, 08:13:41 PM »
I see in the pic you uploaded dhall that it has a 4into1.. too bad it still didn't have the original exh. like Stev-o's bike.
Offline dhall57
« Reply #10 on: July 08, 2016, 09:42:53 PM »
Yeah that was one of the first things I noticed. Bike must of sold hasn't been on CL in several weeks.
« Last Edit: July 09, 2016, 06:09:58 AM by dhall57 »
1970 CB750KO
1974 CB750K4
1976 CB750K6
1977 GL1000
« Reply #11 on: July 09, 2016, 02:08:01 AM »
They had a big heavy 4 into 2 in black, the B1's pipes were painted and the finish was rubbish, the B2 got black chrome pipes, they sound much better with a good 4 into 1. Over here the B2's had the fairing, if that is the case there in the US, that one is a B2....Great bikes...
Offline rb550four
« Reply #12 on: September 12, 2016, 04:08:39 PM »
I had to take a gpz 1100  once, couldn't take the 500 I was buying until the Kaw was on the truck first. It had fuel injection,and all kinds of electrical issues. It was also heavy.
Ended up using the entire front end and entire rear suspension ,wheels, and tank on a 500 frame.
Parted out the rest of the Kaw to a collector. People seem to like them. correction: other people seem to like them.
Offline Sgt.Pinback
« Reply #13 on: September 13, 2016, 02:25:57 AM »
 - Oil burner.  Be prepared for 1,5 - 2 lt per 1.000km and lots of oil dsposal in the head.
 - exhaust (down-) pipes often brake
-  often cylinder haed gasket leakage
-  4th gear tends to jump out
Doc, I love a motorcycle!
« Reply #14 on: September 13, 2016, 05:37:42 PM »
- Oil burner.  Be prepared for 1,5 - 2 lt per 1.000km and lots of oil disposal in the head.
Most of that was fixed in recalls by Kawasaki, not many "oil burners" left, they are bullet proof engines... ;)  Maybe not in the US apparently, although If you go onto any Kawasaki forum you'll find lots of these 1100's still being ridden without problems.. ;)  I had a mate in Sydney with a 1100B2, he replaced the injection with 34mm CV's and it was a real weapon and reliable..
Here's a bit about the oil problem..
BARRELS:  AHH !!!. I COULD WRITE A BOOK ON THIS SUBJECT. BUT, TO SPARE YOU FROM THE BOREDOM I`LL BE BRIEF. THE OIL CONSUMPTION PROBLEM WAS ORIGINALLY PUT DOWN TO THE PISTON AND RINGS. THESE WERE MODIFIED AND THE PISTONS WERE TEFLON COATED AND FITTED UNDER WARRANTY. THE PROBLEM DID NOT GO AWAY. SOMEONE RELIABLY INFORMED ME, OFF THE RECORD OF COURSE, THAT THE PROBLEM LAY WITH THE BARRELS THEMSELVES. IT WOULD SEEM THAT IN AN EFFORT TO REDUCE COST KAWASAKI HAD CHANGED THEIR MANUFACTURING ROUTINE. INSTEAD OF BORING THE SLEEVE OF THE BARREL IN SITU, THEY WERE BORING IT OUT FIRST AND THEN FITTING IT TO THE CYLINDER. ONCE THE ENGINE WAS RUN THE SLEEVE TENDED TO DISTORT CAUSING AN OVAL BORE. THE ONLY ANSWER WAS TO REBORE THE CYLINDER. TRY TELLING THAT TO THE CUSTOMER WHO HAD JUST SPENT OVER £2000 ON THEIR NEW BIKE. YES SIR, A FIRST SERVICE AND OH YES,  A REBORE ! I DON'T THINK SO.!!!! . KAWASAKI RUSHED THROUGH SOME NEW MODIFIED CYLINDERS BUT EVEN NOW THERE ARE MANY BIKES THAT ARE UNMODIFIED AND STILL BURNING OIL. IT SEEMS TO ME THAT THE USA NEVER GOT TO HEAR OF THIS MODIFICATION. ALL THESE IMPORTS SEEMS TO BURN OIL FOR FUN. PERHAPS THE AMERICAN JUSTICE SYSTEM COULD NOT HAVE COPED WITH THE LAW SUITS.!!!
Offline bill440cars
  • Feeling More & More,
  • Tryin' To Slow Down "Time"!
« Reply #15 on: October 06, 2016, 01:25:51 PM »
       I picked up on an '83 GPZ1100, back in the Fall of 2009. Still has the fuel injection and someone put a Kerker 4 into 1 on it. Runs like a Champ. No plans to get rid of it anytime soon. I was concerned about the handlebar layout, at first, but after I rode it, No Problem. If I ever get to where I can post photos again, I will post it up. Never regretted getting mine.
Member # 1969
Offline grcamna2
« Reply #16 on: October 06, 2016, 02:49:34 PM »
Pics ! I love those  :)
Online Stev-o
« Reply #17 on: October 06, 2016, 03:57:41 PM »
There is a project GPz in my area that is tempting.  Been for sale for awhile, maybe I should lowball him?!!
But do I need another Kawasaki??
http://austin.craigslist.org/mcy/5776907575.html
Offline grcamna2
« Reply #18 on: October 06, 2016, 04:29:49 PM »
Why not go there w/ a Kawasaki expert and find out what it's really about ?
« Reply #19 on: October 06, 2016, 08:55:29 PM »
 Ask him about the 500 triple in his  photo Steve.
Online Stev-o
« Reply #20 on: October 06, 2016, 09:13:21 PM »
I noticed that as well!
Offline bill440cars
« Reply #21 on: October 09, 2016, 09:01:56 PM »
Kinda rusty, on posting pics, have to let me brush up on that part. LOL.
Member # 1969
Offline bill440cars
« Reply #22 on: November 14, 2016, 05:51:47 PM »
    I didn't remember if I had posted a photo of my '83 Kawasaki GPZ1100 or not. Needs some detailing, the stripes are fading, the Kerker needs to be prepped and repainted or coated. But runs great and is still running the EFI system. I believe it is stock, except for the Kerker and the pods. Well, and the rear brake line isn't stock either.
Member # 1969
Offline grcamna2
« Reply #23 on: November 14, 2016, 06:02:03 PM »
Nice bike Bill  8)
Offline bill440cars
« Reply #24 on: November 14, 2016, 06:17:26 PM »
Nice bike Bill  8)
       Thank you, I appreciate the compliment. At least I still have this one. I enjoy it myself.  ;)
Member # 1969
