Author Topic: Oil Filter Spring  (Read 5808 times)
Offline gwallis
  • 1976 Honda CB550F 1973 Honda CB750
Oil Filter Spring
« on: June 09, 2016, 03:45:23 am »
OK... I messed up!
It is not critical; but I have a question:
Yesterday I changed the oil on my 1976 CB550F and forgot to re-install the spring that sits between the oil filter and the filter housing.  Naturally I had refilled the engine with oil... so... How important is that spring in the functioning of the flow of oil?  Will it have an affect on the overall oil pressure?
Re: Oil Filter Spring
« Reply #1 on: June 09, 2016, 05:12:14 am »
There may be some oil bypassing the filter.
You are not alone, I was changing oil on my 750 and realized that the spring is missing, not sure how many 1500 miles cycles I was riding without it, there was no problem or damage - but it does not mean it cannot happen.
Your call, I would drain the oil into a clean container and reinstall the spring, just for the ease of mind.
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #2 on: June 09, 2016, 05:20:14 am »
How much oil does the filter housing hold? Remove the filter housing and install the spring. Replace the few ounces of oil lost and be done.
De-Nile ain't just a river in Egypt...
TAMTF...
Wilbur
Projects:
                                           http://oldmanhonda.com/MC/wiring750K1.html
Sent from my Tandy TRS-80!
Offline Johnie
« Reply #3 on: June 09, 2016, 05:58:54 am »
Take a clean container and place it under the filter housing. Take the filter housing off and replace the spring. Install the filter housing and put that clean oil from the container back into the oil tank. Good to go...
1970 CB750K0 - Candy Ruby Red
1976 GL1000 sulphur yellow (current project)
Oshkosh, WI  USA
« Reply #4 on: June 09, 2016, 07:06:33 am »
And don't forget the large washer that is usually lost by sticking on an old filter and getting thrown away. It goes between the spring and the filter.
Offline gwallis
« Reply #5 on: June 09, 2016, 02:56:27 pm »
Guys...good answers all!
I will remove only the housing and see how that goes...makes all the sense in the world...
'Thanks'
Offline Mjoener
« Reply #6 on: August 09, 2016, 06:37:27 pm »
I literally did this same thing on my 72 CB500 Four. I caught it before i started up the bike which meant was able to remove the housing without any loss of oil due to no oil having been ran through the filter yet.
« Reply #7 on: June 26, 2017, 03:34:57 pm »
 Has anyone  found the spring between the filter and engine?  I have. Ditto on the washer.
If you love it, set it free, if it stays it's probably one of my 750's.
Offline Johnie
« Reply #8 on: June 26, 2017, 03:38:27 pm »
Nope, but the washer is always gone.
Oshkosh, WI  USA
« Reply #9 on: June 26, 2017, 05:01:38 pm »
Not having the spring and washer in the right place allows oil to bypass the filter as that was honda's design for a filter bypass valve.  If the filter element were too clogged it would push the filter out allowing the oil to bypass around the filter l is how it was described to me.  So, not having the spring and washer prevents it from operating correctly.
Is this correct?  The washers are not inexpensive if you commonly toss them and end up replacing them often. Makes you want to paint them a hivis yellow or green to prevent that toss it error.
« Reply #10 on: June 26, 2017, 05:21:53 pm »
They get stuck to the filter and thrown away with them.
Offline Kozzjack
« Reply #11 on: June 26, 2017, 06:37:54 pm »
Need some advice on the correct position of the oil filter spring - is it between the filter and the engine housing or between the filter and the oil filter housing??  On my 750Four I found it between the filter and the engine housing and a friend said that is the wrong position.
Thank you in advance for the advice given.
« Reply #12 on: June 27, 2017, 12:00:41 am »
Should have oil cover then spring and then washer then your filter.
Offline Johnie
« Reply #13 on: June 27, 2017, 05:50:48 am »
Spring is between the filter housing and oil filter. The washer sits on the filter rubber with the spring hitting the washer. When you put it together on your bench you lay the filter down so the inside is facing up. I usually put the new filter bolt o-ring in place stick the bolt back through the filter. Then I put on the new housing o-ring. Then slide onto the bolt the spring, washer and insert the filter. Now you are ready to put the unit on the case. Be careful not to cross the threads.
« Last Edit: June 27, 2017, 05:52:55 am by Johnie »
Oshkosh, WI  USA
