Author Topic: Hand shift?  (Read 1986 times)
Offline dperl
Hand shift?
« on: June 09, 2016, 01:55:10 PM »
Anyone done it?
Custom or sourced an existing part?
Curious as to options and parts.
Offline Medyo Bastos
  • Gusto mo titi ko?
    • project
Hand shift?
« Reply #1 on: June 09, 2016, 02:31:30 PM »
not too difficult
...Save a tree, eat a beaver...
« Last Edit: June 11, 2016, 07:26:48 PM by Medyo Bastos »
Offline jukku
  • Happy with my Hondamatic
Re: Hand shift?
« Reply #2 on: June 10, 2016, 02:47:32 AM »
My disabled friend made his sidecar CB750A totally hand controlled.
Installed a rod from the change pedal up to the side of the petrol tank and the rear/parking brake to the left hand using a GL1000 clutch lever.
Offline dperl
Re: Hand shift?
« Reply #3 on: June 13, 2016, 08:30:33 AM »
not too difficult
Was that custom made or an existing part?
  • Gusto mo titi ko?
    • project
Re: Hand shift?
« Reply #4 on: June 13, 2016, 10:54:33 AM »
picked up on the bay
Offline dperl
Re: Hand shift?
« Reply #5 on: June 15, 2016, 12:03:05 PM »
Found 'em!
Thanks
Offline stikman
  • Bit of an
Re: Hand shift?
« Reply #6 on: June 16, 2016, 01:03:25 AM »
I cut off the splined part of the mechanical kickstand neutral switch and welded it to an old Hurst Indy shifter.  Just watch the weight of it and the angle you mount it at.  I ran mine like this for a bit before I mounted it more vertically.  One to many potholes where it would unexpectedly shift itself.   :P
1977 CB750A "High Horse": 836cc, mild porting, custom cam, K5 roundtops, v-stacks...
1973 CB750K D5 plunger frame chopper currently building..
Offline jonnycakes
Re: Hand shift?
« Reply #7 on: June 17, 2016, 08:58:35 AM »
I like leaving it foot shifted and letting people search for the clutch lever
'Matic-Fanatic
Offline dperl
Re: Hand shift?
« Reply #8 on: June 21, 2016, 12:52:22 PM »
I inquired about this on another forum, but couldn't get an answer. If i remove the kickstand connection from that secondary shifter, will it function as a normal shifter, or is it only a safety mechanism? I mean, from the looks of it by your photo, it can function as a normal shifter.
Offline dave the welder
  • dave the welder
Re: Hand shift?
« Reply #9 on: June 21, 2016, 07:02:18 PM »
yes it will work.the other linkage was from the kickstand.when you put the stand down it put the trans in neutralso you could start it without the bike running away
don't buy it build it
