Author Topic: 1976 CB550 K2 First timer - Sold  (Read 41112 times)
Offline Bankerdanny
  • Endeavor to persevere
Re: 1976 CB550 K2 First time builder
« Reply #75 on: June 14, 2017, 09:22:56 AM »
LOL. I'm at work and can't see pictures that are posted from links to the various hosting sights like Photobucket. I only see the ones directly uploaded to the site. So I only saw an X not the shiny bowl.
Offline Smudgemo
  • Maker of Stuff
« Reply #76 on: June 14, 2017, 02:19:41 PM »
I rather get the bike finished and be able to ride it, and polish after ensuring it doesn't leak everywhere and heck, even runs.
It'll run, it's a Honda.
-Ryan
Thread - How to fix your starter button (for real): http://forums.sohc4.net/index.php/topic,163170.0.html
Offline mscuiletti
« Reply #77 on: June 15, 2017, 05:29:51 AM »
I made a template to adjust the float level and buttoned up three of the four carbs. Once I get them all on the rack, I will try my hand at this bench syncing magic. I am glad I tackled this myself because seeing everything move gives me a good idea on how they work, which will hopefully help in future troubleshooting. I haven't harassed the upholsterer in a couple days, but will call tomorrow again. They are not show worthy, but I am proud of how they turned out so far, compared to what they had looked like.
I noticed another mistake when I went to bolt on the brake caliper. I need to look back at photos and read a bit, but it seems that I had installed the disc backwards so that it is sitting darn near the spokes. There is no way in hell the caliper would fit. Guess the front wheel is coming back off.
Offline mscuiletti
« Reply #78 on: June 19, 2017, 05:44:09 AM »
Well i got the front brakes all put together, minus pulling the clip from the rusted fender. I poked a hole in it over the weekend when looking it over.
Now i realize why people keep the airbox. I spent a lot of time reading about what to do with the breather hose. I woudl rathersplit it and route it to the filters rather than just hang a tube with a breather filter. Live and learn, and now is the time all you experts say "I told you so"...  ::)
I thought maybe I could run something similar to the Cognito motors box rather than pods, to retain the open look, while routing the line to it before the carbs:
Offline mscuiletti
« Reply #79 on: June 26, 2017, 05:48:44 PM »
Seat is done. Just mounted it to see how it looks for now.
Offline mscuiletti
Re: 1976 CB550 K2 First time builder - Seat fitting
« Reply #80 on: June 30, 2017, 05:23:39 AM »
Well looks like I will be spending the weekend moving my photos to another hosting site. I may just host my own at this point. Photobucket wants $6 monthly, which is not much, but eventually I would just hit their next limit. In the meantime, I apologize for the lack of photos now. I will get it fixed over the weekend.
« Reply #81 on: June 30, 2017, 07:15:44 AM »
I think everyone has the same issue.  Photobucket can suck it.
Offline mscuiletti
« Reply #82 on: June 30, 2017, 08:36:42 AM »
But then they would charge you afterwards...  ;D
« Reply #83 on: June 30, 2017, 08:47:02 AM »
I'm going to give flickr.com a try.  I hope Photobucket's stock value takes a dump.  I noticed they were inundating the pages with pop up ads, so they were already monetizing the site.  This move is going to piss off users enough to leave their service.  Then the ads won't be worth a damn.
Offline mscuiletti
« Reply #84 on: July 05, 2017, 05:26:42 AM »
Well, I obviously have not fixed any of my links, so I will attach the latest photo just so there is a picture in this thread.
Offline mscuiletti
« Reply #85 on: July 19, 2017, 07:03:06 AM »
I was unhappy with the smoothness of the hoop and welds, so spent some time cleaning them up. I need to bend the pan again to follow the curve of the frame, as the gap beneath the seat bugs me.
« Reply #86 on: July 19, 2017, 08:09:27 AM »
The very slight curve of the seat rails on the 500/550 can be a little bit of a pain.  The Motolanna/Dime City seats fit better because they have some curvature.
image_zpsdfilcfz7 by Donald Leonhardt, on Flickr
CognitoMoto_10_zps08cafwoo by Donald Leonhardt, on Flickr
You can also cut and weld new flat frame rails, but that's a bigger pain.
Alternatively, if you seat has some overhang (below the rails) it can simply hide any small gap.
« Last Edit: July 19, 2017, 08:11:29 AM by SOHC4 Cafe Racer Fan »
Offline mscuiletti
« Reply #87 on: July 26, 2017, 08:06:22 AM »
The pan was made from metal and had been curved to follow the rails, but I think as the upholsterer wrapped it, the pan straightened. I have been slowly bending it back and it looks much better now.
« Reply #88 on: July 26, 2017, 09:01:45 AM »
Great.
Slow and gentle so as to not pull out the upholstery staples or glue.
Offline mscuiletti
« Reply #89 on: October 09, 2017, 05:18:59 AM »
I finally got around to installing new control cables and the master cylinder. I spent quite a bit of time attempting to vacuum bleed the system yesterday and have been pulling a lot of air, but the fluid is just barely dropping in the reservoir. I pulled the top line from the brake assembly to put my finger over the hole while pumping the lever, and although brake fluid oozes, there is no pressure to push my finger away. Should I feel more pressure? I bought the master cylinder "in working condition"...
Offline mscuiletti
Re: 1976 CB550 K2 First time builder - Front brakes
« Reply #90 on: November 01, 2017, 11:22:52 AM »
Bled with zero issues once i replaced the brake line with a single ss line and new pressure switch. However, now the caliper is locked, so I ordered a new seal and will be rebuilding that. Probably all things that I should have done anyways.
Offline mscuiletti
« Reply #91 on: November 03, 2017, 06:00:00 AM »
Check the pads themselves. Often the edge of the pad is painted is just a few hairs too large to retract smoothly. The cure is to gently sand off the paint, and that allows it to move freely.
You have such a plethora of helpful information. I will try that as well, but would you recommend replacing the pads as well? They have a ton of material but I am unsure of the age...
Offline Godffery
  • Godffery's Garage
« Reply #92 on: November 04, 2017, 08:46:39 AM »
 My money is on this:  (I bought the master cylinder "in working condition"...)
Likely a bit of blockage in the tiny return port.
« Reply #93 on: November 05, 2017, 01:17:46 AM »
Never hurts to upgrade the brake hose to Teflon stainless steel braided lines for a no expansion brake line. It will give you solid feedback and the old lines if original have done their job.
A remote possibility that the internals of the lines are failing causing the lines to act like a one way valve.  Clean the tiny hole in the master cylinder with a very small stiff wire and your probably going to have working brakes. Disassembling the caliper (pulling piston) and replacing the seal with a new seal and cleaning the groove is good maintenance. Replacing seal maybe every 8-10 years or as needed. Use good clean fluid, I like Castrol GTLMA but it is hard to find these days.  Not as many places carrying it.  Brake fluid draws water, so it needs to be completely drained/flushed/bled in your brake to purge the old fluid and replaced with clean new fluid a minimum every 2 years.  Using a freshly opened container is recommended so you know it has not been drawing moisture into the container, even with a cap on it it will have water making its way into the fluid.  Water in your brake system can boil causing major issues as well as cause rusting or oxidation of aluminum and other metals.
But, if you can get your master cylinder bled as it sounds like it has a blockage as others have pointed to the small , and we do mean tiny, hole in the Master Cylinder that gets blocked with a tiny piece of debris.
Start with the inexpensive and move to more expensive rather than throwing money at a problem...far cheaper in the long run.
David
Offline mscuiletti
« Reply #94 on: November 05, 2017, 01:13:30 PM »
I mentioned earlier that I had replaced the line which resolved the bleeding. I was unsure of the routing so if anyone has a suggestion. I ran it on the outside of the fork.
20171026_163026 by marc_scuiletti, on Flickr
Here is the new pressure switch:
20171026_163038 by marc_scuiletti, on Flickr
My messy garage:
20171026_163108 by marc_scuiletti, on Flickr
The caliper had lots of crud built up, so I will spend some time cleaning it, installing the new seal, and will install the new pads once they arrive (just ordered):
20171105_154825 by marc_scuiletti, on Flickr
« Reply #95 on: November 06, 2017, 01:09:33 AM »
Heard of a guy or two who ran without fender and had an over the tire line to second caliper and didn't think he was at risk for any damage.  Until his tire caught the line and in the blink of the eye it ripped the hose off and instant no front brakes.
Old fender mount M6 bolt holes can be used to attach a wire or metal tab for your line holder, was going to call it a hose holder, but figured some smart fellow would play with those words.
« Reply #96 on: November 06, 2017, 01:39:51 AM »
Brass will not damage the aluminum, if you have a dremel tool a brass brush in the dremel can clean the slot for the seal very well and fairly quick.  TwoTired has an excellent writeup about how to properly rebuild, refresh your brakes, it should be in the brakes FAQ on the site.
Red rubber grease and Dow High Vacuum Petcock grease, a silicone grease that will not melt and migrate to your pad surface, are highly recommended for your brake system.  The seal gets the red rubber grease or brake assembly lube while the pad back and edges and pivot pin for the caliper mount arm get the silicone grease.
The silicone cannot come in contact with the brake fluid or it contaminates the fluid and would have to be changed.
Offline mscuiletti
« Reply #97 on: November 18, 2017, 01:49:18 PM »
I picked up some grease and a brash dremel attachment this morning and got back to the caliper. After some cleaning, installing the new seal and pads, and bleeding again, I have working front brakes. Progress!!!    :D
I had used brake cleaner to get some of the crud out, but went at it with a brass dremel attachment as suggested.
20171118_141938 by marc_scuiletti, on Flickr
After some cleaning
20171118_143537 by marc_scuiletti, on Flickr
Installed again, minus fabricating a mount to hold the brake line away from the tire.
20171118_150442 by marc_scuiletti, on Flickr
Offline mscuiletti
Re: 1976 CB550 K2 First timer - Fuel system
« Reply #98 on: November 25, 2017, 11:18:47 AM »
Pulled the carbs just to shoot some cleaner and everything is opening and closing. I adjusted the throttle cables to remove most of the slack, however, the assembly does not rest against the pin. I had bench synced the carbs so there is a slight gap still, could that be why? Is this an issue? *Note: the photo was taken before i took slack out of the cable*
20171125_111610 by marc_scuiletti, on Flickr
You can see where the upholster got a bit crooked at the rear of the seat. It will be dropped though so I did not bother having them try again. It was great pushing the bike around and using the brakes.
20171125_120150 by marc_scuiletti, on Flickr
Offline mscuiletti
« Reply #99 on: December 21, 2017, 06:05:13 AM »
To restore the luster of your tank, you can simply wet sand it (lightly, use 1200 grit, then 2,000) and only the top of it. The Black is a single stage paint, the color is multi. The use a quality foam pad to buff it out. You can follow-up with the nano-ceramic coating Marissa recommends for tremendous protection (UV and Chemical). The only trick about the nano coating is the taped on stripes.  :-\
The badges you can restore with some Testers Model paint and shoot some rattle can clear over them.
Took your advice and spent some time sanding and polishing the tank. I like the faded top and scratches. As this is not a restoration, I think it turned out great.
Here was the state of the tank:
20171218_113955 by marc_scuiletti, on Flickr
After sanding:
20171218_115046 by marc_scuiletti, on Flickr
After polish:
20171218_122839 by marc_scuiletti, on Flickr
Installed the new trim and started work on the emblems. I'll sand down the white to a smooth finish and try my unsteady hand and painting the gold and black. Even my small brushes are too large for some of the gaps, so I am hoping a toothpick works. Any suggestions here?:
20171219_181351 by marc_scuiletti, on Flickr
