The bike is done! First startup didnt go quite as planned. I have been in this engine enough and each time the bike fires right up after letting the carbs fill with fuel. Well this time was different. I used the rollers so much that the motor started to get really hot and I drained the battery, which meant it was time to push! So I took to my quiet neighborhood street to get a running start down the small hill up from my house. I ended up pushing it back and forth about a dozen times, and had decided to pull in and pull the plugs to dry them out and start the process again. Well, being the stubborn SOB I am, I decided to try and bump it a couple more times on the way back to the house, and the last try it finally caught and I was able to get it going. I ran it gently up and down the street in 1st gear, varying RPM a few dozen times to try and seat the rings. Not the way I wanted to break it in, but it will have to do. I got back to the garage and with the roller battery charged up a bit and a warm bike, it fired right up to double check the timing one last time.
That leaves me here, Monday before the race weekend, the first of 2021. I will be heading out with the Mrs. on Wednesday afternoon with an overnight in Columbus, OH before getting to CMP in Kershaw, SC in the late afternoon on Thursday. Then its back to business as usual, chasing my uncle in S750 for another run at a championship year, as well as getting deeper into my bump class, Formula Vintage. That class has a number of fast bikes from Vintage Superbike and a couple 2-stroke classes. I will be up against GS1000, KZ900/1000, RZ350, RD400 and a number of other hot rods. I held my own against some of these guys last year, and thanks to me busting my butt in the off season, I am about 2-3hp "lighter" than last year, which should help with acceleration, braking and general handling on the bike.
Here's a shot from right after I got the last things buttoned up. I should be able to get some great outdoor shots at the track soon.
