Author Topic: What are my options for saving this tank??  (Read 739 times)
Offline rocs
« on: June 13, 2016, 07:19:41 PM »
I spent a couple house cleaning the inside of this tank and when i was done, i saw this pin hole on the side.
Is this salvageable? What are my options?
1975 CB550k's
Offline lrutt
Re: What are my options for saving this tank??
« Reply #1 on: June 13, 2016, 07:33:20 PM »
I'd solder it over.
Offline jonda500
« Reply #2 on: June 13, 2016, 07:39:09 PM »
+1 with a small hammer gently tap the hole to below level and then solder or braise it and file smooth.
John
A starter clutch thread:
Offline CycleRanger
  • No comment about being an
« Reply #3 on: June 13, 2016, 08:24:29 PM »
Several options for saving the tank. The paint not so much.  :(
Is the paint a concern?
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
« Reply #4 on: June 13, 2016, 08:48:56 PM »
A competent brazier won't damage much of the paint in that area.
A competent painter will make it look like it was never repaired at all.
Both come at a premium.
Offline mrbreeze
  • Not your average
« Reply #5 on: June 13, 2016, 11:52:23 PM »
Look inside the tank again the best you can. If its just that one little area....braze/solder. If you see more cancer don't waste your time.
MEMBER # 257
« Reply #6 on: June 14, 2016, 04:24:12 AM »
 Definitely line the tank with a good product after you have the hole filled if you try and save it. Has to be more thin metal in there. How rusty is it in there, a de-rust may expose more problem areas.
Offline b52bombardier1
« Reply #7 on: June 14, 2016, 05:04:25 AM »
Yes, definitely derust the tank. If no more pin holes occur, the POR15 urethane kit could possibly cure that with just some painters tape and wax paper over the hole on the outside. I'd probably let a thicker layer cure there or possibly buy two small cans of the urethane for a double layer.
Let's talk a lot more here if you chose the POR15 route for this repair.  Details,  details, details!!!
Rick
Sent from my SAMSUNG-SM-N900A using Tapatalk
1971 School Bus Yellow Aermacchi H-D Sprint 350
1972 Candy Yellow CL100 K2
1972 Candy Jet Green Honda CB500
1973 Mighty Green ST90 K0
1974 Mars Orange CT90 K5
1975 Topaz Orange ST90 K2
1976 Shiny Orange CT90
2006 Honda Foreman 500 (restored)
Offline rocs
« Reply #8 on: June 14, 2016, 05:02:35 PM »
Thanks for the help everyone. I may possibly try and coat the inside if i can inspect it thoroughly to ensure its not completely gone.
The pictures of the tank posted don't do it justice. Its almost perfect looking and then the inside is was rusted. I will put it on the shelf as a garage ornament before i strip the tank.
1975 CB550k's
