Author Topic: Electrical wiring experts  (Read 841 times)
Offline WhyNot2
  • I'm finally an
« on: June 14, 2016, 06:41:41 AM »
I have a run of 125 ft of 10/2 gauge wire going to my pool.
Can I tap into that with 14/2 gauge wire to run to the deck for deck lighting?
If so, how would I create a junction between them under ground?
Thanks for any assistance.
Jack
Re: Electrical wiring experts
« Reply #1 on: June 14, 2016, 06:58:57 AM »
It is preferred to run a circuit for lights and circuit for outlets or other.
Also seems like you need them  both on GFCI?
And as Cal said, splicing underground is a nono.
Offline demon78
  • After work to the "Wets"
« Reply #2 on: June 14, 2016, 08:03:19 AM »
I would not splice them under ground it can be done with specialized wire and junction boxes, insulating material but it is a #$%* to have to repair/dig up for any reason and because of moisture etc. the joints don't last as long normally as far joining the wires it's fairly common using a junction box if ti was me I would fuse the 115 volt line separately from the other also think about underground wire and a telltale above it to cut down on people accidentally digging it up. I ran mine in plastic conduit with a yellow ribbon over top. I know that seems extreme but you don't need problems in the future.
Offline WhyNot2
  • I'm finally an
« Reply #3 on: June 14, 2016, 02:10:42 PM »
Thanks for the replies.
Advise well given, and advise well taken.
The 10/2 wire I dug and ran myself, electrician advise a 20 amp GFCI circuit breaker. Paid the plus 40 bux.
He installed and checked my work.....all ok.
There is of course a junction box in the attic where I miscalculated and bought 10/2 wire 15 feet too short.
So being the nice guy this electrician is, he happen to have just enough to finish the run.
So.....could I tap into that with this 14/2.......only reason for the 14/2 is I bought 250 feet of it and I can't return it, so may as well use it.
Once again......thanks guys.....
Even the county inspectors gave the ok stamp. Of which they were out here inspecting the addition of a rather elaborate sun room my wife wanted.
Offline danyo
« Reply #4 on: June 17, 2016, 05:07:25 PM »
If you want to be up to code you can't use 14 Awg on circuit connected to 20 Amp breaker. Find other lighting circuit on 15 amp breaker and make a splice or if you have more spaces in breaker box, run directly there and install separate 15 Amp breaker.
Sent from my SM-N900T using Tapatalk
Offline WhyNot2
  • I'm finally an
« Reply #5 on: June 18, 2016, 04:30:26 AM »
Thanks man.....will do...
