Author Topic: What's your favourite method of fuel tank de-rusting?  (Read 10638 times)
Offline drumstyx
« on: June 18, 2016, 09:37:13 PM »
Contemplating how I'm going to de-rust my very rusty '78 750 tank. I was almost set on naval jelly, which is definitely the cheapest and easiest option, but I saw a review that seemed to say metal rescue did a fantastic job, while naval jelly (in fairness, not diluted with water to spread it) didn't do much.
Problem is, Metal Rescue is $30CAD/gallon, and you can't dilute it. That's what, $150 + tax to fill one of these tanks? Yikes...
So what does the community prefer?
Re: What's your favourite method of fuel tank de-rusting?
« Reply #1 on: June 18, 2016, 10:31:01 PM »
Kleen strip prep n etch.  $15.
5 hours of soaking and turning...
Photo taken during drying after a few water rinses and an acetone gargle.
« Last Edit: June 18, 2016, 10:33:25 PM by flybox1 »
« Reply #2 on: June 18, 2016, 11:17:23 PM »
Yep, phosphoric acid is the best way to clean a tank. It's pretty harmless (is used in Coca Cola, metal polish and lots of commercial cleaners, not to mention fertilizers) and does a great job. I've tried all the other methods, but Phosphoric Acid is the best. Cheers, Terry. ;D
Offline Djfob
« Reply #3 on: June 19, 2016, 12:15:44 AM »
Since your talking cad dollars I'm assuming you're up north like I am. Reason I went with metal rescue is that I couldn't get my hands on phosphoric acid from any known Canadian retailers.
78 CB750k
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
« Reply #4 on: June 19, 2016, 12:50:32 AM »
Metal rescue worked alright for me.
But that gallon cost $10 more than what flybox used.
Offline dusterdude
« Reply #5 on: June 19, 2016, 02:39:49 AM »
The works toilet bowl cleaner,love it
Sent from my LG-D850 using Tapatalk
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline calj737
  • I refuse...
« Reply #6 on: June 19, 2016, 03:21:01 AM »
Household Distilled White Vinegar is perhaps the cheapest option. Fill the tank completely, soak, rinse and flush with Prep 'N Etch for a protective layer. Done. Vinegar runs about $1/gallon.
« Reply #7 on: June 19, 2016, 04:15:30 AM »
 I am in the Works toilet bowl cleaner camp also.
Offline b52bombardier1
« Reply #8 on: June 19, 2016, 05:31:03 AM »
I do like phosphoric acid and I also like the "Calcium, Lime, Rust CLR" bathroom cleanser.   Getting anything mentioned here and above hot . . . boiling even . . . seems to help in getting rust and varnish out of the tank. The heat softens up the stains and rust and seems to generally rev up the chemistry.  I use an old camping stove to get it hot and then agitate the tank with a hundred or more nuts, bolts, washers, screws, railroad spikes and old sledgehammer heads to break up the rust.  Don't forget to turn the tank upside down to clean the top surface - even though you can't see it, it'll be rusty and stained, too.  Just kidding about the spikes and hammer heads but you get the picture.  And boil whatever fluid you use outside because it can stink up the house pretty bad.
  Whatever method you chose here . . . . DON'T BE IN A HURRY.  This could take a week or more of active effort on your part to get it all cleaned out down to bare metal.  A good effort here in getting it all cleaned out will pay dividends in the next steps of discovering any pin holes in the metal and when you finally put in whatever liner you chose to prevent future rust.
  The fuel tank on my current CB500 resurrection took a week to get clean and I really thought it would be pin holed but it wasn't. And then the urethane liner went in from a motorcycle-sized "POR 15" kit (in silver urethane, not black) and it has worked out great.  This was my seventh POR 15 tank repair and I have never been disappointed but preparation is the key for any tank liner you chose.
Rick
« Last Edit: June 19, 2016, 05:34:47 AM by b52bombardier1 »
1971 School Bus Yellow Aermacchi H-D Sprint 350
1972 Candy Yellow CL100 K2
1972 Candy Jet Green Honda CB500
1973 Mighty Green ST90 K0
1974 Mars Orange CT90 K5
1975 Topaz Orange ST90 K2
1976 Shiny Orange CT90
2006 Honda Foreman 500 (restored)
Offline Bodi
« Reply #9 on: June 19, 2016, 06:14:06 AM »
Assuming you're in the Dominion, Home Despot has concrete floor etch in a 4L jug - pretty cheap. Meant to clean your garage bike shop floor before epoxy painting. It's exactly phosphoric acid solution and it eats rust like Garfield eats lasagna.
Offline drumstyx
« Reply #10 on: June 19, 2016, 06:36:45 AM »
Not planning on lining this tank. I've never heard a good word about liners from people that have used them long-term. People have great things to say when they've only used it for a year or 2, but I constantly hear or peeling liners in tanks that were lined 5+ years ago
« Reply #11 on: June 19, 2016, 07:28:35 AM »
They peel because of poor surface preparation or they leave too much urethane in the tank on the bottom  which delaminates later.
Avoid these problems and I've never had one go bad. I did my first tank back in 2009 and it is still perfect.
Rick
Sent from my SAMSUNG-SM-N900A using Tapatalk
Offline Tews19
  • I am no
« Reply #12 on: June 19, 2016, 07:32:47 AM »
This is my method as well. I spray the inside out with my pressure washer. Then fill 1/4 wheel water and baking soda to coat the inside.... pressure washer inside again for several minutes. Fill with gas and done
1970 Honda CB750 survivor.
Offline Hwmetzger
« Reply #13 on: June 19, 2016, 08:50:51 AM »
White vinegar and an aggregate (such as large bolts or gravel) works incredibly well. I've restored a pair of CB200's, SL350, and a KZ440 in this manner. I just fill up the tank, add aggregate, and shake it up every once in awhile while I'm working on the rest of the bike. Rinse well with water, coat with WD40 and she's good to go.
Offline Johnie
« Reply #14 on: June 19, 2016, 09:47:52 AM »
If you are not going to line it then you don't need the etching stuff. I just did a tank and used Metal Rescue for the first time. I bought a 5 gallon pail from Amazon for $93 and free shipping. The tank came out real nice. I let it sit for about 22 hours. Tank nice and shiny. I strained the chemical out and can reuse it. Once the Metal Rescue was out I put in a new petcock, flushed it with a gallon of gas. Dumped out the gas and filled the tank with my no ethanal fuel. No flash rust doing it this fast. I did not want to mess up the paint which is why I do not like the Works. Just to caustic.
« Last Edit: June 19, 2016, 09:50:41 AM by Johnie »
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
« Reply #15 on: June 19, 2016, 06:50:03 PM »
For guys living in the country, go to a farm supply store and buy a gallon of "Phos wash" or similar, it is 100% Phosphoric acid used for cleaning dairy equipment, it runs for about $30 (AUD) for a 5 litre jug, and can be diluted up to 10:1, which then weakens it to about the same strength as white vinegar.
White vinegar is great for light rusting if you don't mind waiting for a few days, but  Phosphoric acid will remove the heaviest rust in a couple of hours. Cheers, Terry. ;D
Offline Wingnut74
« Reply #16 on: June 19, 2016, 06:57:22 PM »
I had a tank with a thick layer of varnish and rust to boot. Did acetone and screws and lots of shaking and soak time, two weeks probably. Then bit the bullet and filled tank with metal rescue. When you are done with metal rescue if you rinse with water you have to blow dry the tank pronto to avoid flash rust. Mines looks factory new inside - was very pleased. Got enough metal rescue to last ten years now though
74 CB360 - Winter 2014/2015 Project
74 CB750 - Winter 2015/2016 Project
70 Something TBD - Winter 2016/2017 Project
Offline Lostboy Steve
« Reply #17 on: June 19, 2016, 07:18:48 PM »
Washing soda and a battery charger works really well for me.
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
Offline drumstyx
« Reply #18 on: June 19, 2016, 09:25:07 PM »
If I went with just 1 or 2 gallons of the stuff, maybe I could get away with rotating the tank every 24 hours for a couple days?
Offline calj737
  • I refuse...
« Reply #19 on: June 20, 2016, 03:19:13 AM »
Acetone will eat the paint. Metal Rescue will not. Not sure with your last post which product you were going to "get a gallon or two" of to swirl in the tank.
Offline Wingnut74
« Reply #20 on: June 20, 2016, 06:57:38 AM »
Acetone and screws were for the varnish, and agreed - it will eat paint too, though I was not super careful thinking I would repaint any way, just wiped acetone off the paint when I spilled and it looks perfect (at least where I spilled).  I tried using less Metal Rescue and rotating it but I started spilling it out too much before I replaced tank gasket and it seemed like a PITA, but I bet you could make it work.
Offline Djfob
« Reply #21 on: June 20, 2016, 07:50:50 AM »
Metal rescue works best filled all the way, swirling around go with something stronger with products mentioned above.
78 CB750k
Offline chewbacca5000
  • I polish covers!
« Reply #22 on: June 20, 2016, 08:29:19 AM »
$9.39 Sherwin Williams wood bleach.  It nuked the rust and it has not come back.
http://www.sherwin-williams.com/homeowners/products/catalog/wood_bleach/
No hoping on left foot or reciting special incantations required.
« Reply #23 on: June 20, 2016, 08:36:57 AM »
interesting.   assuming you mixed it per instructions.
how bad was your rust and how long did you let it soak?
any issue with tank paint?
Offline bochnak
    • How-To Motorcycle Repair Blog
« Reply #24 on: June 20, 2016, 08:40:01 AM »
I've used both vinegar and Evaporust with good results. You do have to be patient though:
https://www.howtomotorcyclerepair.com/restoring-a-rusty-motorcycle-tank/
I highly recommend Caswell epoxy if you do have to coat it.
Sometimes pinhole leaks appear after derusting and you have to coat it.
