Author Topic: Help with this piece on my engine...  (Read 2157 times)
Offline Foyil100
« on: June 19, 2016, 09:41:52 PM »
Hi All,
I removed my oil tank today in order to clean up my bike a little bit and I noticed this piece sticking out of the motor and I had no idea what it is...Can someone help me out? Should it just be as it is in the picture or is something supposed to be over it (a hose of some sort..?).
Thanks!
Sean
« Last Edit: June 24, 2016, 06:22:33 PM by Foyil100 »
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
Re: Name this piece on my engine...
« Reply #1 on: June 19, 2016, 09:47:50 PM »
It most certainly is a hose connection.
I'm not a 750 owner, but I'm fairly certain an oil hose belonged there
« Reply #2 on: June 19, 2016, 09:50:21 PM »
That is the oil tank overflow tube.  If your oiling system gets backed up into your oil tank, it has to be safely routed back to the crankcase.  Get a hose on there asap.  It connects to the bottom of your oil tank.
Offline Foyil100
« Reply #3 on: June 19, 2016, 10:54:45 PM »
Thank you! I had a local shop install a aftermarket oil tank on the bike (haven't started it or even filled it with oil yet) and I noticed one of the hoses went from the tank to under the bike..similar to a dirtbike fuel overflow hose that just hangs down. It definitely wasn't connected to the bike  :o
Good thing I asked! Thank you!!
« Reply #4 on: June 20, 2016, 04:48:53 AM »
 That hose you described may be the aftermarket tanks vent and may possibly not want to be connected to that fitting. A stock honda tank has both an overflow and vent, your new one may not. Post a picture of it for the folks.
« Last Edit: June 23, 2016, 05:58:02 AM by ekpent »
Offline Foyil100
« Reply #5 on: June 22, 2016, 10:16:36 PM »
I'm using the Cognito Moto oil tank seen below and here: https://cognitomoto.com/products/bolt-on-cb750-oil-can
Its the smaller one on the far left.. The two large one connected to fittings on the bottom right side of the engine.
Offline Bankerdanny
  • Endeavor to persevere
« Reply #6 on: June 23, 2016, 12:54:27 PM »
I think Fred is a fine name, Frederico if you want something more exotic.
Offline carnivorous chicken
« Reply #7 on: June 23, 2016, 01:14:06 PM »
Beat me to it, I was going to suggest "Terrence" or "Terry" for short.
Offline Foyil100
« Reply #8 on: June 24, 2016, 05:57:00 PM »
Haha I see what you did there....
Offline Foyil100
Re: Help with this piece on my engine...
« Reply #9 on: June 24, 2016, 06:23:28 PM »
Does anything need to be attached to this piece or can I leave it the way it is?? I believe the third hose on my tank is a breather
  • Holy Cow! I'm a
« Reply #10 on: June 25, 2016, 02:10:06 PM »
What flybox said.
Offline Foyil100
« Reply #11 on: June 26, 2016, 11:47:18 AM »
Here's the problem.. The oil tank (shown above) has 3 hoses, 2 run to the engine on the bottom righthand side and the third (smallest of the three) is a "breather hose" according to Devin at Cognito Moto (created of the tank). He said it can just hang down under the bike.
Should I connect that "breather" hose to that piece on the engine? Or should I plug that piece?
Thanks!
Offline Phinn
  • Subversive
« Reply #12 on: June 26, 2016, 12:54:08 PM »
Definitely connect it. If that rear-facing connector on the crankcase is left open, oil spits out the back and all over your rear wheel.  That's what my PO did, and because motorcycle oil leaks go everywhere, it's one of the sources of oil spatter that I've been cleaning off my bike since the day I got it.
1978 CB750K -- "Mouse," a former basket case, resurrected
Offline Foyil100
« Reply #13 on: June 26, 2016, 01:23:27 PM »
Okay thanks for the info! My only concern is will it cause any problems having the "breather" hose connected to that?  I mean.. What is the breather hose used for? Is it bad for oil to go up there?
Online Don R
« Reply #14 on: June 26, 2016, 01:51:25 PM »
 Maybe run a hose up to a tee, connect to the top breather and then to a K&N breather or the airbox?  It should only pass air and  that would allow any oil venting out the top a chance to re enter the crankcase.
 A local shop had a 750 in with oil leaks everywhere, the PO had sealed the hose nipples with silicone.
« Last Edit: June 26, 2016, 01:54:55 PM by Don R »
Offline Phinn
  • Subversive
« Reply #15 on: June 26, 2016, 02:39:22 PM »
That's how the stock oil tank is configured -- two main in/out hoses, and one breather connection to that nipple on the lower rear crankcase.
There is a second breather on top of the engine, in the valve cover, which (on the 78s) connects to a separator that hangs below the battery box. It separates the output into liquid and gas, sending the liquid to a filter and then the street, and the gas back into the airbox.
But the lower breather connector you've been asking about just goes to the oil tank.  These breather connections and hoses are there to deal with the expanding gases and occasional small quantities of overflow that occur due to heat and other operating conditions.
Offline Foyil100
« Reply #16 on: June 26, 2016, 05:37:23 PM »
Thanks Phinn!
Okay so I'll connect the breather hose to that part of the engine. Therefore all 3 hoses will be plugged into the engine and no hoses will be hanging down. Mine is a 1978 CB750F Supersport, however I don't have any other hoses hanging down that might be a pure breather for gasses. I just want to make sure the bike will be able to release any gasses is needs to...
