Author Topic: Next generation of petrol head is underway!!  (Read 9757 times)
Offline Daggless888
Re: Next generation of petrol head is underway!!
« Reply #75 on: October 13, 2016, 06:29:17 PM »
yes definately. the restrictors are 1mm from speedflow who supplied all the fittings and lines. these were placed into the 2 lines straight after the T joiner. whole conversion went well with only a small leak on one of the banjo bolts into the head. this was rectified easily with a bit of honda bond.
« Reply #76 on: October 13, 2016, 07:53:34 PM »
Not sure what you're using but copper washers are better than aluminum here.
Offline Daggless888
« Reply #77 on: October 13, 2016, 11:32:40 PM »
Sister of Cognito clone :-)
« Last Edit: October 14, 2016, 02:49:48 AM by Daggless888 »
Offline Daggless888
« Reply #78 on: October 13, 2016, 11:50:39 PM »
cheers Bwaller. They came with alloy but if I get any weeping will change over to copper.
Offline Daggless888
« Reply #79 on: March 20, 2018, 12:50:19 AM »
took the time today to get the bike on the dyno. It was really close with the cr carbies as supplied from godfreys. Had to lift the needle 1 notch and a little bit of playing with the screws. Really happy with the result. The bike is really singing and a pleasure to ride. Loving it
