Author Topic: Loose swingarm bushings, what do I do?  (Read 2179 times)
Offline Jon T
« on: June 20, 2016, 11:09:23 AM »
Hello all i'm rebuilding my swingarm for my 1973 CB750K. It seems this has been done before, because the old bushings I removed were steel, and I recall reading that replacement bushings were steel for a while. It looks like i'm going to need a new collar as well, the old one didn't clean up too nicely, anyway onto the problem. I ordered bronze bushings from kenosha_kid on ebay, as recommended on here. They arrived today and I went to test fit and was surprised to find they slip right in by hand. Not too easily but I can spin them while they're in by hand. I looked up a couple of posts and this seems to have happened before but I couldn't find a straight answer. Will I need custom bushings to be made or will I have to sent my swingarm out to get professionally rebuilt, I think HondaMan does that? Theoretically could I lube the bushings up with a little JB Weld and shove em in? It doesn't sound right and i'd rather do it the right way but if that is a safe solution i'd take it. What do you guys think? Thanks -Jon
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
Re: Loose swingarm bushings, what do I do?
« Reply #1 on: June 20, 2016, 11:21:42 AM »
I'm a fan of the aluminum can shim in a situation like that
Offline drumstyx
« Reply #2 on: June 20, 2016, 11:56:49 AM »
I wouldn't glue them in!
If I had a machine shop though, I wouldn't hesitate to line the tube with a bit of epoxy, let it cure, then drill it out. Aluminum can shims might do alright. I've got bushings coming from the same seller too, hope not to have this issue!
Offline riffman12
« Reply #3 on: June 20, 2016, 11:59:03 AM »
depends how loose we're talking. After going in the freezer, I could push mine in with some muscle and my hand + a bit of grease. Didn't have to use any kind of press or anything. However, once all put together there is no play in the swingarm.
If it's lose enough that things move laterally, then you have a problem.
Offline strynboen
    • http://forums.sohc4.net/index.php?PHPSESSID=3hucl42do3lq6t61gdt6lnski4&/topic,60973.0.html
« Reply #4 on: June 20, 2016, 12:06:42 PM »
il vill use lockteit..after klean all vell up..so no oil or dirt can blend up ...
i hate all this v-w.... vords
Offline Dunk
« Reply #5 on: June 20, 2016, 01:13:31 PM »
Depends on how loose the fit is. Turns easily with significant clearance all aorund or takes a little effort to push in though can still turn it with slight resistance? If it's hotdog down a hallway I'd not be comfortable with it. If it has some resistance tot runing and can't be rocked and such I'd likely use a bearing and sleeve retaining compound. The second link says up to .015" clearance... though that seems way big for what I'd be comfortable using it for in a swingarm.
https://www.amazon.com/Loctite-37424-Strength-Retainer-6-milliliter/dp/B0002KKTIG
https://www.amazon.com/Loctite-234772-Temperature-Retaining-Compound/dp/B003T7UXUI/
Offline Jon T
« Reply #6 on: June 20, 2016, 08:00:29 PM »
Thanks all, just got off work. It is not hotdog down a hallway loose, it has no play up or down whatso ever. It isn't easy to move around and pull out by hand but I wouldn't call it hard to move. Not sure if that helps. Will look into the locktite
Offline Garage_guy_chris
« Reply #7 on: June 20, 2016, 08:17:47 PM »
The problem is the collars end up worn and undersized so new bushings end up loose when they start life. Someone should start making undersized swing arm bushings, then the collar tube can be reduced in diameter 0.010" to 0.020" by the end user to provide 0.002" clearance then everything would be happy and provide a nice long service life.
I was planning on ordering some oversize undersize bushings from McMasterCarr and doing just this on my own bike. Just haven't got around to it just yet
Offline chewbacca5000
  • I polish covers!
« Reply #8 on: June 20, 2016, 08:33:57 PM »
I just installed a set from kenosha_kid, and they worked out great.  Used some 1/2" threaded rod and some wheel cone balancers and they pulled right in.  I could not be happier with the fit.  This swing arm is rock solid!
How easy id your old bearings come out?  It might be possible they were turning inside the swing arm increasing the ID of your swing arm.
Offline Jon T
« Reply #9 on: June 20, 2016, 08:51:06 PM »
Had to cut one side and beat it out with a big hammer and punch and then floated a correct sized socket down and beat that to get the other one out. Wasn't too hard, didn't break any tools or even score the swingarm so im happy.
Offline CycleRanger
  • No comment about being an
« Reply #10 on: June 20, 2016, 08:58:37 PM »
Yeah, I've installed 4 sets of bronze bushings from Kenosha_Kid (aka TwowheelsFrank)
Every set was a perfect fit.
You should collect some measurements of your swingarm and the bushings and PM Hondaman.
He'll have all the answers. :)
Offline Jon T
« Reply #11 on: June 20, 2016, 09:01:36 PM »
I don't think its the bearings cause I first ordered the wrong set from vintagecb750 a while ago and realized so and ordered from kenosha_kid. I just tried and both have the same fitment
« Reply #12 on: June 21, 2016, 04:46:49 PM »
Loctite will solve your problem,  beer can too thick.
Offline rotortiller
« Reply #13 on: June 22, 2016, 07:05:58 AM »
Yup loctite sleeve retainer would be my first choice. Then I'd make sure the inner sleeves protrude out of the bushings a few thousands of an inch total. Easy to check, easy to shim or file to spec as the frame has some give. It isn't rocket science LOL
rt
« Last Edit: June 22, 2016, 07:45:07 AM by rotortiller »
