Author Topic: Honda cb750 clutch information  (Read 844 times)
Offline stevena
« on: June 22, 2016, 03:51:08 PM »
Hey guys I am in dyer need to find carbon friction clutch discs that will fit a stock cb750 clutch basket. Hope to get some answers on where to find some!
Offline oldskullero
Re: Honda cb750 clutch information
« Reply #1 on: June 24, 2016, 04:45:28 PM »
Are you gonna use it for racing, or street and daily driving only. I can point you to check their mods but let me ask you, is it the sohc or dohc engine.
Sent from my SM-N9005 using Tapatalk
« Reply #2 on: June 26, 2016, 05:57:41 AM »
Make sure you order correct model of clutch discs.
The later from 1975-76 got the outer disc with wider ears and different pattern (Clutch basket has wider space for the disc). Older clutch has 7 discs of same model.
Use std clutch with Barnett springs. "Race proven" clutch are reported as sticky. Search the forums and you'll find. I had CycleX that stucked overnight.. I had to rock bike forward-backwards with 2:nd gear in and clutch lever presses until it got loose.
Later: http://www.ebay.com/itm/76-78-HONDA-CB750K6-CB750K7-CB750F2-CLUTCH-FRICTION-PLATE-1145-/161408453864?vxp=mtr&hash=item2594b18ce8
Earlier: http://www.ebay.com/itm/HONDA-CB750K1-CB750K2-CB750K3-CB750K4-CB750K5-SEVEN-CLUTCH-PLATE-SET-CD-1133-/141982017807?vxp=mtr&hash=item210ec9a90f
I use K6 discs as above and so far OK in my +80 rwhp engine. Made in China but has not started to fall in pieces yet. I think that more and more parts are made in China, eben if the label on package is well known.
« Last Edit: June 26, 2016, 06:02:33 AM by PeWe »
