Author Topic: "Wiring problems" Two issues-  (Read 902 times)
Offline DWS
  • Treat others as you would like to be treated .
« on: June 23, 2016, 11:52:51 AM »
"Wiring problems" Two issues- on a 78HondaCB750F3
1- left blinker works when orange and white blinker wirer is disconnected, if I connect it, the left blinker stays on solid bright without blinking. been this way for awhile now.
2- My head light is blowing its five amp fuse. just started doing this.
All other blinkers and tail light our working fine.
I've check old archives and can't find my issue.
Thanks for any help in advance!
« Last Edit: June 23, 2016, 11:54:46 AM by DWS »
Always looking for friends.
78CB750F3
PD 42A with original breadbox
4 into 1
valves adjusted to .003 (intake and exhaust) ( as was suggested for cooling )
slow jets#35 Main #110
 turned out to 1.5 some paper work says 1.75
4800 feet altitude
78 Honda CB 750 F3 Restoring now(Almost done)
BSA MX 50 Next
BSA b50T Parts
Re: "Wiring problems" Two issues-
« Reply #1 on: June 23, 2016, 05:55:51 PM »
The headlight fuse should be 7 amps; the tail-light fuse is 5 amp.
Offline DWS
« Reply #2 on: June 23, 2016, 09:38:55 PM »
Thank you! I did figure out the fuss problem, the blinker is a different story
78CB750F3
4 into 1
4800 feet altitude
BSA MX 50 Next
BSA b50T Parts
Offline Deltarider
« Reply #3 on: June 25, 2016, 01:31:03 AM »
I don't know if you have a model where the front indicators double as running lights. If that is so, maybe wires are switched somewhere or duplolamp has been installed the wrong way. Consult your wiring scheme for this.
CB500K2-ED Excel black
Offline Phinn
  • Subversive
« Reply #4 on: June 25, 2016, 06:19:20 AM »
Yes, the 78s have dual filament running light/blinkers in front, and single-filament blinker-only lights in back. They all use the same flasher relay, so if they work somewhere, it's probably not the cause.
1978 CB750K -- "Mouse," a former basket case, resurrected
Offline DWS
« Reply #5 on: June 29, 2016, 12:31:51 AM »
OK cool that was the problem, did not know it had running lights, and the left front bulb had two filaments and the poles where backward and the right front bulb only had  one filament so that's way it looked wired, thanks for the help guys.
78CB750F3
4 into 1
4800 feet altitude
BSA MX 50 Next
BSA b50T Parts
Offline Deltarider
« Reply #6 on: June 29, 2016, 02:35:11 AM »
Do yourself a favour and disconnect those running lights that make your bike look silly and as childish as a fairyground ride. There's no science that supports they add to safety - personally I believe the contrary is true - and they waste a precious 16 Watts. When I think of all those millions and millions of unnecessary lights on US vehicles, it's such a waste of energy. When translated in oil, that's quite a pond, isn't it.
« Last Edit: June 29, 2016, 04:21:11 AM by Deltarider »
