Author Topic: Ignition Coils  (Read 918 times)
Offline JetgreenK1
  • Works good, lasts a longtime
Ignition Coils
« on: June 25, 2016, 11:46:41 AM »
Hello all,
I have a 1971 K0 CB500 and have ran into an issue. The original ignition coils we on the bike, but not attached as someone (previous owner) decided to cut them off.  I just put on new coils and despite my attempts to find where which spark wire goes with each spark plug I can't seem to find it on any schematic. Any helpful places to look or pictures of your own bike I could go off of?
Many thanks in advance.  Vintage all the way!
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
Re: Ignition Coils
« Reply #1 on: June 25, 2016, 12:07:11 PM »
Follow your ignition leads from the points (or electronic ignition). The blue wire feeds coil 1/4 while the yellow wire feeds 2/3. So the coil that has the blue wire attached to it connect its spark plug leads to 1 and 4, and the coil with the yellow wire attached connects to 2 and 3. Order of 1/4 and 2/3 does not matter since each coil fires both leads at the same time (one is "wasted").
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline JetgreenK1
Re: Ignition Coils
« Reply #2 on: June 25, 2016, 07:39:44 PM »
Madmtnmotors
Thanks a ton! Glad to have kind folks like you around! These schematics are only helpful to a certain degree.  I'm headed back to the garage to finish this out! Really appreciate it!
Re: Ignition Coils
« Reply #3 on: June 26, 2016, 06:34:29 AM »
Happy to help. It does not matter which side the coils are mounted on either, just follow the blue/yellow:
>Blue-1/4
>Yellow-2/3
TAMTF...
Wilbur
Projects:
