Author Topic: 4 into 1 pipes all the same?  (Read 1140 times)
Offline cleveland
« on: November 20, 2006, 04:59:21 PM »
I am picking up another parts bike and I like the pipes on it.  Mine is a 77 CB750K with a 4 into 1.  The parts bike is a 76 CB750K with 4 into 1.  Can I swap them with out re jetting?
Thanks, cleveland
Offline cafe75-550
Re: 4 into 1 pipes all the same?
« Reply #1 on: November 20, 2006, 05:10:52 PM »
      Probably, but re-jetting would be determined by the difference in the amount of restriction each system has. Changing from 4-4 to 4-1 or vice versa, or to open pipes, changes the restriction a lot so re-jetting is usually required.
    In your case, if the systems are similar it shouldn't be a problem, but if one of the set-ups has significantly more or less restriction it might be necessary to re jet (ie, if one of the systems has had its baffles removed etc). In that case you could just try to swap the header section and keep the muffler, since the difference in the headers should be  pretty minimal (but that probably defeats the purpose if the pipes are that different...)
New bike!
'07 Triumph Speed Triple 1050
Never enough projects!
'75 CB550 "Cafe", '76 CB550 parts bike
'64 Norton Atlas featherbed/'71 Triumph 750 Triple (Triton project)
'68 BSA Thunderbolt (frame and cases, project in the wings)
'57 Triumph Thunderbird (frame and mostly complete engine)
Offline nteek754
  • 1973 K3/750/836/70 1970 750 chopper 1973 cafe
« Reply #2 on: November 20, 2006, 05:12:21 PM »
d me down kerkers on I did too much off roading and not much clearance under there  but she said like night and day sound performance she lves it hey there yu will have to deal with the spigot issue if they are still on the 76  like with kerker whn you install one of their pipes (my favorite) you need to take the spgots out by removing the flathead screw in the head use an inpact  then you use  the correct mm bolts to instal the kerker now mac however use the spigots and the stock star clamp  I put a hand me down kerker on sisters 74 750 k and she said like night and day  sound and performance now we run no baffle justthe cone piece in the end with no jetting needed  good luck seven fifty four ever Craig in Maine
seven fifty four ever its not the destination its the journey Ive been collecting these old dinasours for 33 years . they are quite an ICON
Offline cleveland
« Reply #3 on: November 20, 2006, 05:28:21 PM »
GREAT!  They look pretty much the same except one is chrome and the other is painted.  You can see in my avatar that the last guy that had this bike painted the muffler grey.  :-\  This guy did a pretty crappy job too, because there is grey paint on the frame to.  >:(
Offline cb650
« Reply #4 on: November 21, 2006, 04:06:03 AM »
Dont you just love that!   Last bike I parted had overspray on everything.   Well at least I'll know what bike the parts came off of.
                              Terry
