Author Topic: lacing a wheel  (Read 77841 times)
Offline Clyde
Re: Wheel lacing experts, need advice!!!
« Reply #150 on: September 18, 2007, 05:43:30 PM »
I have used Buchanan, Hagon and some local AUstralian made spokes. They all do that to a varying degree. The rear was harder than the front to get together, but both looked OK when tightened up.
Make sure you do the radial adjustment first, then correct any side movement afterwards
Regds Clyde
SOHC4 #1909
Honda CB750 K0(original and unrestored), K1(in pieces), K2(restored), F1(restored), 76 750a (awaiting restoration), 1966 Honda CB72
Suzuki GT750 1972 (restored), Kawasaki Z1 1973 (restored)
Offline rhinoracer
« Reply #151 on: September 18, 2007, 10:49:13 PM »
Thanks both, I'll go ahead and tighten the spokes then.
Baja native.
Offline tsflstb
What am I doing wrong? - wheel lacing pics - SUCCESS!
« Reply #152 on: September 26, 2007, 09:05:08 PM »
I've been scratching my head for 2 days now.  Maybe I'm missing the forest for the trees here, but I can't figure this out.
I've read the excellent write-ups in the FAQ section and I think I'm following them correctly.  I've got the inner spokes on both sides laced up OK.  Yesterday I started trying to lace one side of the outers at a time and ran out of slack on the last side.  Today I tried doing one outer from each side at a time and still can't get the outer spokes started.  I'm pretty sure they're going in the right holes.  There are holes offset to each side and going in opposite directions, but maybe I have it indexed wrong?
The spokes are stock length, just thicker.  The only wild card here is the rim is not custom for my hub, but I was told it is drilled for an 8" full width hub just like mine.  The spoke pattern is not looking like the stock wheel.  Is there another pattern for a 36 hole rim?
Does anything jump out at you in this pic?  I've got the inners installed on both sides and started doing one outer per side.  I can get about 3 of them in before I just run out of slack.  The spoke on the far side at about 12 o'clock is the last one I tried installing, but it won't reach it's hole.
Here's the difference in length sticking out of the rim.  The inners seem like they're not angled enough or something.
Stock wheel for reference:
« Last Edit: September 27, 2007, 06:16:15 PM by tsflstb »
Offline Patrick
Re: What am I doing wrong? - wheel lacing pic
« Reply #153 on: September 26, 2007, 09:38:39 PM »
If you have the old spokes compare the new ones to the old ones. Make sure they are the same length and make sure the angle of the bend in the spoke at the hub is the same for the inside and outside. If the hub, spokes and rim were now designed to go together you might have to modify that bend to get it all to line up. Also, make sure you are not switching the outer spokes with the inner spokes.
I spent several hours a month ago unsuccessfully trying to lace a wheel. When I discovered the angle being a little off it took about 30 minutes to finally lace it up.
Truing that sucker is where the real adventure begins....
Good luck.
Patrick
1970 CB750 K0
1982 VF750S Sabre
1987 VT1100 Shadow
1979 Yamaha XS11
1969 Yamaha DT1B
etc.
Offline crazypj
  • I'm brill, me
« Reply #154 on: September 26, 2007, 11:34:46 PM »
It look like your only going 3 holes instead of 4?
 You have 36 hole hub but I see 8 sets not 9 4x8=32, 4x9=36
PJ
« Reply #155 on: September 27, 2007, 03:47:24 AM »
Try installing ALL the spokes in the hub first and fiqure out the cross pattern. You can even use a little electrical tape where each pair of spokes cross to hold them somewhat. If you have another wheel to go by so much the better. Then lower the rim over the whole thing and it should be obvious by the angle of the hole in the rim, which spoke goes where. It then takes a little patience to install the spokes in the proper orientation, and it may be necessary to remove some of the tape here. When it appears everything looks right start installing spoke nipples radially outer & inner just a turn first until you can get them all on.
It's tough to tell by your pic but it doesn't appear that you've found the correct pattern.
Good luck
Offline rhinoracer
« Reply #156 on: September 27, 2007, 09:24:51 AM »
PJ
He's right, you should be going 4 holes to obtain the desired pattern.
Thicker spokes will make it harder to fit the outer spokes but they do fit, so that shouldn't be causing your problem. I just went thru that myself.
That the rim was drilled for an 8" hub doesn't mean it'll use the same length spokes as stock, different rim profiles use different length spokes, so you should check on that also.
You can tell the outer spokes from the inner spokes by the bend, outers have a tighter bend. I say this because it seems in your pics that the inner spokes are way too long and the outers are way too short, so if you don't have them mixed you probably need different length spokes.
Baja native.
Offline tsflstb
« Reply #157 on: September 27, 2007, 09:43:06 AM »
I'm pretty sure I have the right spokes.  They may all need to be ground off at the nipple once installed since this Akront rim has a little more drop in the center.  Something is definitely off since the outer spokes won't even reach the rim.
I'm not following you here.  Do you mean 3 holes between spokes on the same side?  I think I've got the spokes in the only way they'll go.  Once you start the first one, there's only one other hole on the rim facing that side, and it's drilled in the opposite direction.
I'm confused because the inners went in great, the rim seemed true, and now the outers are getting in a bind.  Unless this rim was really meant for some kind of conical hub I can't see how it would happen.  That's got me wondering if the rim itself is drilled for another pattern.  Just eyeballing it against the stock rim, the spoke pattern looks identical.  I guess it doesn't take much to throw everything off though.
Possibly the stupidest question ever -- does it matter if I flip the rim over (reverse the direction of rotation)?  I wouldn't think so, but I'm grasping at straws now.
Thanks for the ideas.  I've emailed Buchanans to see what they say too.
Offline mlinder
  • "Kitten Puncher"
  • Stop Global Tilting now!
    • Moto Northwest
« Reply #158 on: September 27, 2007, 10:01:30 AM »
Note the difference at the hub. I've marked lace holes with blotches of colors to show.
No.
Offline tsflstb
« Reply #159 on: September 27, 2007, 10:17:08 AM »
I agree the spoke pattern just doesn't look right.  Your dots make me realize that I've got two inner spokes crossing where an inner and outer should cross.  -Edit - but it looks like we're talking about two different sets of spokes.  The blue one I highligted is on the near side, the red is on the far side.
My brain is hurting now...I'll unlace it again tonight and start over.  Hopefully it's something I'm doing wrong and it will come to me.
« Last Edit: September 27, 2007, 10:29:49 AM by tsflstb »
Offline Bodain
  • I love the smell of fresh asphalt in the morning!
« Reply #160 on: September 27, 2007, 03:33:42 PM »
Hee hee... I laced up a 16 in. Harley type wheel to a Honda CB 750 rear hub.... Had nothing but grief..
Bought a set of spoke on Ebay claiming to be for this task. They simply would not work. Too long.The seller insisted the spokes were fine. I purchased another set of spokes from Ebay. These were slightly shorter. Still wouldn't work. It was like the inner spokes didn't have enough angle on them...
Finally I saw a picture of a laced wheel doing exactly what I was trying to do. ALL the spokes came from the inside of the Honda hub. Instead of alternating inside, outside.
This worked! But I still had to cut about 1/4 inch off each spokes and retap them.
Finally it all came together...
2009 Suzuki TU250
2014 Honda Grom
1988 Yamaha FZ600
2018 Honda Ruckus
1971 Honda CB500
Offline tsflstb
« Reply #161 on: September 27, 2007, 06:15:45 PM »
I got a reply from Angel at Buchanans this afternoon.  He must have seen this before.  I think this is what some of you guys were trying to tell me too.
The reason why you are having a problem lacing the wheel is because the stock rim was drilled standard Japanese and the new rim is drilled non-standard European. For this reason the spokes can not be laced following the marks. What you need to do is reverse the inner and outer spoke direction on one side and it will work fine. Leave the drum side laced the way you have it now but reverse the direction of the top side spokes of picture one.
This thing practically laced itself once I switched directions.  Here it is after both sides of inner spokes:
And with the outers:
Now I just need to take it all apart again, polish the hub and spokes and maybe powdercoat the rim.  I feel much better knowing it will work (and I'm not a complete idiot).  Maybe I should wait on that last comment until I have it trued up.
Offline rhinoracer
Re: What am I doing wrong? - wheel lacing pics - SUCCESS!
« Reply #162 on: September 27, 2007, 08:24:15 PM »
There you go!  :)
Baja native.
Offline Jinxracing
  • It's hot shit, not
  • '70 CB750 K1
    • The Hairy Nickel
« Reply #163 on: September 27, 2007, 09:08:10 PM »
Thanks for posting the solution! I was waiting to see how it all turned out...I'm going to be lacing my wheels in the not too near future.
Sounds like Angel deserves a six-pack.  ;)
–Captain Horatio Hornblower
www.thehairynickel.com
Offline tsflstb
« Reply #164 on: September 28, 2007, 05:45:24 AM »
Yeah, that guy knows his stuff.  Hopefully this will broaden your options if you want alloy rims.
If you're cheap like me, search Ebay for old dirtbike wheels, Maico, Montessa, Husky - I think this one came from an Ossa.  They're old Spanish dirtbikes that used Akronts stock.  Their rear hubs are very similar to the 36 spoke Hondas.  Be patient and you can snatch one up cheap.  I got the one I'm lacing in the pictures for $9.99.  For the 40 hole CB750s, there are more options out there.
I never found any 18", 36 hole take-off rim from another bike that would fit the front, so I'm having a shouldered Excel rim custom drilled.
Offline Patrick
Spoke lacing patterns?
« Reply #165 on: December 04, 2007, 09:03:45 AM »
I have seen pictures of spoked wheels with fancy lacing patterns. I was wondering if anyone knows a website that shows how these patterns are achieved?
My thought: my K0 750 came with a replacement rear hub and a NOS rear rim. It also came with a new set of stainless steel spokes. The problem is the spokes are longer than stock by about 1.25 inches. Too long for the 18" rear, too short for the 19" front. It seems a shame not to use them, so I was wondering it a different lacing pattern is possible that might accommodate the extra length.
It seems unlikely, but you never know. Ideas, anyone?
Patrick
1970 CB750 K0
1982 VF750S Sabre
1987 VT1100 Shadow
1979 Yamaha XS11
1969 Yamaha DT1B
etc.
Offline .RJ
  • homebase in your airspace
CB750 w/ 16" rear lacing pattern
« Reply #166 on: December 04, 2007, 11:15:46 AM »
I laced up the rear wheel what I thought was per the directions, and this is what I had:
And took them to the honda dealer for truing - they said the lacing pattern isnt right, the spokes were binding up against each other.  Am I missing something, or should I just get a spoke kit that laces inside/outside just like the stock spokes?  They are going to try lacing it up a different way and see if it worked, but I dont want them to use up too much time on it.
newcbguy
Re: CB750 w/ 16" rear lacing pattern
« Reply #167 on: December 04, 2007, 11:30:16 AM »
thats the way the 16" wheel I have is laced. all from the inside. I talked to a guy who laced them in out and he said that he had to hit them (with a hammer) and bend them to lace them the other way  :o
didnt plan on him lacing any wheels for me anytime soon!
Offline .RJ
« Reply #168 on: December 04, 2007, 11:32:49 AM »
I was originally going to powdercoat the hubs and spokes, and I have a set of spokes from buchanan (sp?) that lace just like stock, inside/outside - but they're painted, I'd have to strip the powdercoat off and then have them plated if I wanted to use them.
Offline .RJ
« Reply #169 on: December 04, 2007, 02:12:39 PM »
Turns out I laced them wrong - they fixed it for me and they'll be ready tomorrow :rock:
Next time I will just leave everything up to the pros :)
Offline ekim98
« Reply #170 on: December 04, 2007, 02:28:36 PM »
That's how mine is too. I haven't had any problems at all, but I haven't been over 102 mph yet either.
Patriot Guard Rider - KY. Ride with Respect
78 750k  cafe bike sort of
67 305  Superhawk (working project)
Offline Triffecpa
« Reply #171 on: December 04, 2007, 03:00:19 PM »
RJ
Can you post a pic of the wheel after the "experts" fixed it?
Thanks
Tracy
Offline .RJ
« Reply #172 on: December 04, 2007, 03:25:06 PM »
Sure thing - I pick 'em up saturday (the dealer is 2 hrs away, no one around here knew what a spoke was).  I'll try to grab a pic before I rush to put them on the bike :)
Offline chopstar500
  • King of the Nighttime World
« Reply #173 on: December 04, 2007, 04:27:07 PM »
Yeah... that's the wrong lacing pattern - technically, you should have inside and outside spokes vs. all inside spokes. Looks like you got that squared away though!
Completed Project "Four Pack" - My 1971 CB500 KO - Now For Sale - email me for more info!
Offline flipprboi
« Reply #174 on: December 04, 2007, 05:21:19 PM »
nice wheels though! Can't wait to see the bike
-benjie
