Author Topic: lacing a wheel  (Read 77069 times)
Re: Buchanans spokes lacing
« Reply #375 on: May 15, 2009, 01:17:33 PM »
I'll post a picture of my 17" if it will help. It doesn't have the rotors on it, just the hub. spokes and rim.
Offline Burnboy
« Reply #376 on: May 15, 2009, 02:51:37 PM »
Ya thatd be great. After fooling with it I got the spokes in  the only concern I have is that on the outside spokes the threading comes past the nipple, only about a quarter of an inch though. I know custome spokes are usually ground off at the ens once done but is a quarter of an inch margin ok?
1975 CB750
1973 CB350F
Offline drdreas
  • 77' CB750k
« Reply #377 on: May 15, 2009, 02:57:47 PM »
I also laced a 17" rim to my front hub using a cross 3. Theres no reason it shouldn't work with a 16" rim. This is the wheel during the lacing process.
« Reply #378 on: May 15, 2009, 03:40:30 PM »
On the 17 I laced to my rear, I had about 6 spokes with threads I had to grind off. Gigawhiskey I think had about 20. It happens. If the wheel trues up, grind off the excess and party on.
Offline kghost
« Reply #379 on: May 15, 2009, 03:54:04 PM »
Wish you'd change the title of this thread...
Has nothing to do with Buchanans Spoke lacing....
Stranger in a strange land
« Reply #380 on: May 15, 2009, 03:59:03 PM »
Warning thread hijack!!!
Have you installed your 17" yet? Are there brake caliper clearance problems?
Offline drdreas
  • 77' CB750k
« Reply #381 on: May 16, 2009, 05:29:35 AM »
Hey MCRider, yeah I got it installed. From my last thread, I had the disc on backwards and that was causing obvious caliper issues, I flipped it and the caliper fits just fine now. The clearance from caliper arm to rim is very tight (less than 1/8"), but it doesnt touch.
I'll update that thread to continue the discussion. I'll post pics on monday.
« Reply #382 on: May 16, 2009, 06:43:08 AM »
I remember that thread, didn't realize it was you. THat's good news as I'm sweating it. But, "an inch is as good as a mile".
I first heard that in the context of raodracing. WHen you've got 3 people heeled over in turn one, near 100mph, a front wheel nearly touching someone else's bike, just rememeber, doesn't matter how close you are, as long as you don't touch.
