Author Topic: So lean it was running rich!  (Read 917 times)
Offline eigenvector
« on: June 30, 2016, 04:47:24 PM »
Struggled with this one for a long while - took a bit of back to the basics thinking to finally figure it out.
Had a bike that was sooting up the plugs, leaving them wet, running with no off-idle power.
"Must be running too rich"
So I knocked myself out trying to cure that.
It was at the point where I had the pilot screws open only 1/2 turn that I started to think I had it all wrong.
I fixed a bent rod on the enrichment circuit - still ran rich.  Poured half a bottled of Seafoam into the tank - got better but still ran rich.
Threw my hands up and said "F it!"  Took it out on the road - struggled but once it got up to temp it smoothed out somewhat.  Real pain in the neck to ride, because it struggled to get past 1500 rpms - but once you got past that it zoomed to 4k.  Barely got warm.
Turned the pilot screws out to 1 1/2 turns, tried it again - almost serviceable at this point.
Guess I'll turn the pilot screws out to 2 and see if that doesn't get it to where it needs to be.
My best guess - once I figured out the enrichment circuit, I had it leaned out so much in the idle circuit it was starving for gas and in order to get it over 1500 rpm I had to open it up and dumped in too much fuel - sooting up the plugs.
Lesson - if you find yourself needing to go to the extreme on an adjustment, you're solving the wrong problem.
Rob
2018 HD Softail Heritage
1979 CB750K Limited Edition
1977 CB550K
1984 CB700SC Nighthawk
1983 VF750S Sabre
Re: So lean it was running rich!
« Reply #1 on: June 30, 2016, 07:59:29 PM »
I once drank so much whiskey I got sober! Oh, wait, I thought this was the BS thread... ;D
Offline tbpmusic
« Reply #2 on: July 01, 2016, 11:51:29 AM »
I once got so stoned I couldn't remember if I was stoned or not....so I smoked some more !!
Bill Lane
