Author Topic: Removing a tack weld  (Read 1417 times)
Offline eigenvector
« on: July 02, 2016, 05:39:48 PM »
Come to find out the previous owner of my bike removed the stock baffles from the muffler and tack welded in their own open system.
Fair enough, but I want to put the original baffles back in - question is, what's the best way to remove a tack weld on a circular object like a muffler can?  Sure sure, I can/will grind off the surface mounds - but undoubtedly the insert and the shell have been welded inside.  I don't want to grind off huge chunks of muffler shell trying to break the weld - and one of those welds is REALLY ugly - like "I don't know what I'm doing, but I'll tack weld it anyway" ugly.  I only welded as part of my engineering curriculum - and I could have done better than what they did.
So my question - if I do grind off the surface weld, will that likely be enough to separate the shell from the baffle?
I'll snap a photo and upload so you have an idea of what I'm talking about.
Rob
2018 HD Softail Heritage
1979 CB750K Limited Edition
1977 CB550K
1984 CB700SC Nighthawk
1983 VF750S Sabre
Offline eigenvector
Re: Removing a tack weld
« Reply #1 on: July 02, 2016, 05:55:30 PM »
The welds in question
Rob
1977 CB550K
1983 VF750S Sabre
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #2 on: July 02, 2016, 06:51:55 PM »
I think once you grind the surface down you will find that there was not much penetration of those welds. You should not have to go too deep, and it might fall out once you grind the surface off.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline chewbacca5000
  • I polish covers!
« Reply #3 on: July 02, 2016, 07:07:09 PM »
I agree.  Remember it is not legit unless there are some sparks.
Offline eigenvector
« Reply #4 on: July 02, 2016, 08:25:18 PM »
Kind of why I was asking Cal.  But - no harm grinding them down flush with the top of the shell.
Funny you guys mentioned sparks - that "baffle" if that's what you can call it, was running so rich that the tip of the muffler was coated in about 1/4" of oil, sludge, gas, you name it.  No spark arrestor on this baby! :)
The other one isn't as bad as this one - I'm guessing the shell being out of shape made it difficult to tack.
The thing that annoys me - those small holes in the baffle are the mounting holes, why the heck didn't they just use them?  3 or 4 pop rivets and no need to tack it.
Rob
1977 CB550K
1983 VF750S Sabre
Offline eigenvector
« Reply #5 on: July 03, 2016, 02:27:52 PM »
Well one of them is out.
Almost got the second one but I ran out of Dremel discs.  Will make a store run in a bit.  The first one is sitting in the Berryman's can to get rid of all that spooge that collected on it over the years.
Welds were pretty shallow all told, that big mountainous one went pretty deep, but it was also real gloppy and so once you started to cut through it the rest cracked and gave way.
Like I say - I don't have a clue why they didn't just use the mount holes - they're right there staring you in the face.  Instead they burned through the shell with terrible welds.
Glad I got the grinder - made short work of the surface welds, making it quicker to dremel out the cracks.  Also glad I wore my faceshield - dremel disc shattered throwing fragments into my face.
The surface finish wasn't a concern for me Cal - the welder took care of that long before I ever got it.  That said - when it's done I'll need to thoroughly degrease, clean the metal of any remaining tack weld spots, and then hit it with high-temp paint.  Or it will rust.
Rob
1977 CB550K
1983 VF750S Sabre
