Author Topic: Steering head bearings  (Read 6846 times)
Offline eigenvector
« on: July 05, 2016, 09:46:59 AM »
Have to adjust the steering head bearings on the bike.  When I was bombing around the neighborhood I noticed that it thunked and clunked when turning or hitting bumps.  Stuck my thumb under the upper bearing collar and noticed movement when the brakes were applied.  I jacked it up and the forks are solid, no lateral or fore/aft movement in the wheel.  The handlebars rotate very freely with no indication of catch points or dragging.  It was my understanding that it should drag a little.
So I'm assuming the stem isn't snugged down enough.
This morning I stuck a 30mm socket on it, attempted to budge it, but wasn't able to.  Looked at the service guide and they mentioned that it should be torqued from 62 to 90 ft-lbs.  Aside from that being a huge margin, that's pretty tight to say the least.  Tighter than I would have ever expected - heck the bearings on my truck aren't that tight.
Ultimately my question is thus - should I loosen it up, then snug it down again in case it just wasn't torqued enough, or should I just remove the stem and repack the bearings?  I don't see any indication of worn bearings, which is why I'm not leaning that way - but I've never rebuilt a steering stem so I don't know.
Rob
2018 HD Softail Heritage
1979 CB750K Limited Edition
1977 CB550K
1984 CB700SC Nighthawk
1983 VF750S Sabre
Offline CycleRanger
  • No comment about being an
Re: Steering head bearings
« Reply #1 on: July 05, 2016, 10:05:32 AM »
Ultimately my question is thus - or should I just remove the stem and repack the bearings?  I don't see any indication of worn bearings, which is why I'm not leaning that way - but I've never rebuilt a steering stem so I don't know.
Yes! Be prepared to catch all the bearings when they fall out...
If you've never been in there before you should at the very least clean & repack the bearings.
Better still, while you're there just install tapered bearings.
Offline Bankerdanny
  • Endeavor to persevere
« Reply #2 on: July 05, 2016, 10:31:45 AM »
Which bike?
This article is very helpful: http://www.motorcycleproject.com/text/shucking.html
Offline eigenvector
« Reply #3 on: July 05, 2016, 10:58:15 AM »
Well I have to remove the front end anyway to rebuild the instrument cluster - so why not (other than it being a pain)?
Not something I'll do today, looking like rain so for now I'll just begin the process of stripping off the front end so that I can work on the instrument cluster in the shop.
This is my Nighthawk in case you're wondering.
I wanted to spend the day organizing the shop and putting my tools away - not tearing bike apart after getting it running again.
Rob
1977 CB550K
1983 VF750S Sabre
Offline CycleRanger
« Reply #4 on: July 05, 2016, 11:29:15 AM »
The Nighthawk probably has tapered bearings so you can probably just get away with cleaning and repacking them.
Offline eigenvector
« Reply #5 on: July 05, 2016, 12:07:15 PM »
Nope!  :)  Assuming the shop manual photo is correct.  Looks like ball bearings.
Gonna be apart for a few days so I can get tapered bearings if need be.
Rob
1977 CB550K
1983 VF750S Sabre
Offline CycleRanger
« Reply #6 on: July 05, 2016, 12:16:00 PM »
Huh, I didn't bother to look but I assumed Honda would have switched by then.
Ah well,
« Reply #7 on: July 05, 2016, 02:54:13 PM »
eventually they did at least cage them...my 86 vf500f Interceptor has caged ball bearings...apparently not rally an improvement as they need work, just like the loose balls, after only 18,000 miles
Offline brewsky
« Reply #8 on: July 05, 2016, 04:27:06 PM »
The nut that adjusts the bearing tightness is UNDER the top tree, not the one on top.
You have to remove the top tree (or at least loosen the top fork pinch bolts, top bolt, and top tree clamp pinch bolt (if there is one) to adjust the bearing tightness. It's done with a notched nut that requires a spanner or special socket.
66 CA77
78 550K
78 CB750K
02 FZ1
09 GL 1800
« Reply #9 on: July 05, 2016, 10:03:16 PM »
Brewsky is correct. Also, over-tightening the nut can damage even new bearings, by "dimpling" the races, especially with ball rolling elements. In no case should the adjustment nut be tightened to 90 ft-lbs!
« Reply #10 on: July 05, 2016, 10:05:13 PM »
Your stock shock adjuster wrench is also called a steering stem nut adjuster wrench.
Offline Bankerdanny
« Reply #11 on: July 06, 2016, 02:07:18 PM »
It is also called a pin spanner
Offline CycleRanger
« Reply #12 on: July 06, 2016, 02:17:37 PM »
Or a pin wrench.
One time I tried asking at Home Depot about one of these because they're also used for some plumbing applications.
Three different employees got huffy with me because they didn't know what it was and therefore it couldn't be a real tool.  ::)
Offline eigenvector
« Reply #13 on: July 06, 2016, 03:51:20 PM »
Well, that's why I asked.
Shows you how much I know about steering head bearings.  I understand now why it's 65 to 90 ft-lbs - it's the triple-clamp nut.  The steering head nut is something else entirely.
In either case it sounds like a learning opportunity in the making.  I'll start dismantling while the sun is out.
Rob
1977 CB550K
1983 VF750S Sabre
Offline CycleRanger
« Reply #14 on: July 06, 2016, 04:51:40 PM »
Hope they don't look like this!  :o
My XS650.
Offline eigenvector
« Reply #15 on: July 06, 2016, 04:56:43 PM »
I hope not, but so far they're dry as a bone.
Got the upper removed, pretty simple really.  I was expecting it to be a knucklebusting challenge, but honestly once you loosened the pinch bolts, then broke the triple clamp nut loose - it all came apart no problem.
When I say dry as a bone I mean it, I don't see any evidence of grease so far.  Nothing under the top cap, not even those hard crusties that dry grease leaves.
Rob
1977 CB550K
1983 VF750S Sabre
Offline eigenvector
« Reply #16 on: July 07, 2016, 07:52:42 PM »
Well that was easy.
Removed the uppers plus the race, both looked fine.  Jacked the bike up and dropped the stem out enough to clean the lowers.  The bearings were caged so nothing escaped.  I do believe they had the original grease on them - it looked very similar to the grease you would get from a Harbor Freight bearing, that vasoline stuff.  Barely any of it - unless you count road grime.
Cleaned them up with brake cleaner, wiped them down, packed them with a good marine grade grease and partially reassembled.
Won't be able to fully reassemble until I can get a proper tool to torque the upper nut.
Rob
1977 CB550K
1983 VF750S Sabre
« Reply #17 on: July 07, 2016, 08:45:24 PM »
Put an aluminum bar or drift against  it and tap it  gently.
Offline NobleHops
  • Don ya be callin' me no
  • Misfit - Tucson, Arizona
« Reply #18 on: July 07, 2016, 09:23:50 PM »
Attaboy. Go read that link that was offered and follow that procedure for tensioning the bearing and you'll likely get it perfect on your first try. You'll need a spring scale, like you'd use to weigh a delicious bass.
N.
I have a motorcycle problem.
« Reply #19 on: July 07, 2016, 09:47:07 PM »
I do not agree with Mr. Nixon's recommendation for over-tightening the bearing preload to seat the bearing races in the neck; that's like driving the outer race of a wheel bearing into the hub on the inner race, through the rolling elements. That's not how it's done.
Offline NobleHops
« Reply #20 on: July 07, 2016, 10:27:48 PM »
Would you feel a bit better about it if you knew the procedure he describes was lifted primarily out of one of the Honda CBX FSMs?
« Reply #21 on: July 07, 2016, 10:37:31 PM »
No, Nils, it wouldn't. ;) The handling fault with the early CBX was the flimsy plastic swing-arm bushings, not the steering stem bearing pre-load. One simply does not seat bearing races by applying pressure through the rolling elements.
« Reply #22 on: July 07, 2016, 10:56:13 PM »
Note rule #8.
Offline NobleHops
« Reply #23 on: July 08, 2016, 01:34:29 PM »
Note rule #8.
Ya, I hear ya man, understand the concern. But as prior, that process Nixon refers to is Honda gospel too, and as I have done it several times, I absolutely can feel the bearing squaring up in the pockets as I rotate the steering head to and fro, and the action of the steering head gets much looser as it does. We're not talking about excessive torque IMO and it's not on the rollers for long either.
On the other hand, if a bearing gets installed without some mechanism like this to get it seated, loosens as it seats (which it clearly does in my personal experience), then the rollers are getting hammered as the bike goes down the road because it has play. Plus you have to remove the top bridge to fix it, when it comes back because the bearing is too loose :-).
So pick your poison I guess. I like the Nixon/Honda method.
« Reply #24 on: July 08, 2016, 02:01:17 PM »
Note rule #8.
+1, 50 ft. lbs spread evenly over two tapered rollers is probably way less damaging than the pounding they get when they get loose.  I have never tried this before but I know I have had to re-tighten everytime after 1000 miles or so.
