Author Topic: 1971 CL350 Craigslist find  (Read 23805 times)
Offline Scott S
Re: 1971 CL350 Craigslist find
« Reply #75 on: July 24, 2016, 08:35:13 AM »
Pretty sure Ricks sells a Reg/Rec for that bike. I used one on Cognito's Fox 350 build, but don't recall specifically if it was a Ricks or an ElectroSport. I installed it in the base of the seat tube, bolted in from behind. Made it very easy to connect to stock wiring, with a bit of extensions soldered in. Open air, fully concealed placement.
 I'll definitely look into that.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline grcamna2
« Reply #76 on: July 24, 2016, 09:01:56 AM »
I've heard about a Radio Shack rectifier but Radio Shack is now defunct. I'm not even sure at this point what the culprit is.
I use these: http://www.ebay.com/itm/35-AMP-3-THREE-PHASE-BRIDGE-RECTIFIER-WIND-/261313978134?
The manual has the instructions for testing the rectifier.
I assume you've already checked/cleaned all the connections.
 Not yet, other than the battery cables. I just stuck my meter on it while I had it running. I'll go through it and see if I can trace it down.
One very bad place for corrosion is the battery box and where it actually is grounded directly to the frame where it mounts,the rectifier mounts/grounds to it.. I clean all those mount/ground places up good and then use di-electric grease.
75' CB400F/'bunch o' parts'
Offline Scott S
« Reply #77 on: July 24, 2016, 11:46:59 AM »
 It wasn't bad at all, but I cleaned it up and put it back together; no change. Aaaaand, of course the regulator and stator wiring are behind the LH air filter and beneath the battery box. Which means they are inaccessible with the exhaust on.
 I'll probably just leave it as is until it's time to remove the exhaust to install the bodywork and make sure that I check/repair/replace whatever needs it before installing the exhaust again.
'71 CB500 K0
'81 Yamaha XS650
Offline Scott S
« Reply #78 on: August 03, 2016, 04:45:02 AM »
 Fixed the turn signals. Installed a $4 flasher, replaced a bulb, cleaned up a couple of connections and, as expected, found some better grounds for the front turns. They all work now. Only oddity is that the turn signal indicator in the dash only flashes when the LH signals are on, not the RH.... Hmmmm....
 Installed a new high beam indicator bulb, replaced the front brake switch. All electrical seems to be working now. The neutral indicator light is sometimes iffy. I cleaned and adjusted it on the cam under the sprocket cover, but I think it needs a little tweaking to make full contact. No biggie.
 Now that I finally have a solid tank, I think I'm going to throw a splash of gas in it and ride it for a few miles. Keep adjusting the clutch and making minor tweaks. I don't think it'll be long until I take it to the body shop for paint!
'71 CB500 K0
'81 Yamaha XS650
Offline Scott S
« Reply #79 on: August 03, 2016, 01:11:19 PM »
Installed the petcock and hooked up the tank today and did a little test riding around the neighborhood. I was able to get the clutch and carbs adjusted pretty well.
 But when I stopped for a clutch adjustment, I noticed gas along the seam on the LH side of the tank. Then I noticed the blister:
 Crap. Not again?! Drained the gas and stripped the tank to bare metal. It's not looking too good. These all showed up. They've been dug out with a pick tool, so that's all the soft metal I can find. At first, I thought it was just a couple and could maybe be saved. But the more I cleaned, stripped, wire brushed....
 There are even a couple on the RH side.
 That's tank #3 with holes. I'm in dire need of a SOLID CL350 tank.
'71 CB500 K0
'81 Yamaha XS650
Offline Scott S
« Reply #80 on: August 03, 2016, 07:29:45 PM »
 I used a pick tool and dug out until I got solid metal. I suppose it could be saved, but first I need a couple of gallons of acetone to get the Redkote liner out!
 I have a line on a pretty nice (supposedly) tank. At this point, I don't mind paying a little extra to get a GOOD one.
'71 CB500 K0
'81 Yamaha XS650
Offline MoMo
  • Ride like you're invisible
« Reply #81 on: August 03, 2016, 07:39:25 PM »
that's a shame Scott.  I can imagine a CL tank is hard to find.  Good luck....Larry
Offline Bankerdanny
  • Endeavor to persevere
« Reply #82 on: August 04, 2016, 11:33:38 AM »
Scott, try calling Clint at Motolane, a motorcycle salvage yard in central Illinois: 217-674-3793.
His website, which he is very bad about updating, shows he has a gold '71 CL350. I have bought a couple things from him in the past and he has been easy to deal with.
Danny
Offline Scott S
« Reply #83 on: August 04, 2016, 02:07:00 PM »
 Thanks Danny. I think I have a nice one on the way. Fingers crossed!
'71 CB500 K0
'81 Yamaha XS650
Offline bender01
« Reply #84 on: August 09, 2016, 07:16:05 PM »
Barn find law? Ive got to look into that! Did you start at the DMV or tax assesor or where? Ive had nothing but troubles here in Beaufort county! No recent registration or title from another state no issue! Bill of sale doesnt matter where its from. Thats the answer I get.
 Thanks for a where to start. Ive got one now thats a minty project I was thinking of parting or let Georgia have it. They dont need much there.
75 550 K1
74 750 K4
1968 450 K1 Super Sport
74 750k 836 project
Good luck!
Two Tired Quote !
Offline Scott S
« Reply #85 on: August 09, 2016, 07:32:32 PM »
 You have a PM.
'71 CB500 K0
'81 Yamaha XS650
Offline Scott S
« Reply #86 on: August 10, 2016, 05:02:11 AM »
 The seat that came with the bike was on a solid pan and had been recovered, but I hated the shape. Way too soft and round. Plus, whatever foam they used was WAY too soft. I literally sunk down to the pan on it.
 For about the cost of a new seat cover, I found a stock seat. Ahhh.....much better!
 I also found a Triple A brand luggage rack. Cleaned it up a bit and got it mounted.
'71 CB500 K0
'81 Yamaha XS650
Offline grcamna2
« Reply #87 on: August 10, 2016, 06:08:19 AM »
Scott,
That seat looks a lot better,how does it ride? The rack looks like a good fit.
Offline Scott S
« Reply #88 on: August 10, 2016, 06:57:51 AM »
 I haven't ridden it with the new seat yet but it feels much better.
'71 CB500 K0
'81 Yamaha XS650
Offline Gene
  • Chat enuf you too can be a
« Reply #89 on: August 10, 2016, 09:55:54 AM »
Man, that's a good looking bike.
*1973 CB750K3 (Bow)
Offline Scott S
« Reply #90 on: August 10, 2016, 12:27:20 PM »
 Thanks! It will be when I'm done!
'71 CB500 K0
'81 Yamaha XS650
Offline Scott S
« Reply #91 on: August 10, 2016, 12:37:30 PM »
 Since I've ridden the bike and it did OK, and I'm pretty much at the body work stage, I removed the exhaust....for a couple of reasons. It has to be off to install the LH side cover (whenever it's finally painted) and, more importantly, to test the charging system stuff that's behind there/under the battery box.
 The GOOD news is that the stator tests good. I get 1.1 - 1.2 Ohms between the Yellow/Pink wires and 0.6 Ohms between the White/Pink. That means the problem is with either the regulator or rectifier. I can't really test the regulator without the bike running and it's partially disassembled right now. Doesn't really matter which one is bad because I'm replacing them both with a Sparckmoto combination Reg/Rec. Got it ordered today.
 I tried to install a new grey clutch cable today since the old one was so hard to pull. Something I got off eBay. First, it was about a foot longer than the old one. OK....I can work around that. Then I found out that the guide that goes in the sprocket cover didn't fit. Swapped over the one from the old cable. THEN, as I was adjusting the cable, it pulled right out of the barrel at the lever!
 I've requested a refund and ordered a new cable from 4into1.com
 So, I had a running bike, and now it's in pieces again!
 Hopefully, the new tank will be here soon, too.
'71 CB500 K0
'81 Yamaha XS650
Offline tbpmusic
« Reply #92 on: August 10, 2016, 01:50:54 PM »
Yeah, you have to take off the mufflers to do about anything on a CL - lay in a good supply of those copper exhaust flange gaskets........
The cable, incidentally is the same as a 450 except for the sprocket cover guide.
Bill Lane
Offline Scott S
« Reply #93 on: September 25, 2016, 12:09:39 PM »
 Got the bodywork back. Need to install the gas cap. The badges are off at a local pinstriper getting detailed. As soon as I get this back together I can start on reassembling the bike.
'71 CB500 K0
'81 Yamaha XS650
Offline grcamna2
« Reply #94 on: September 25, 2016, 01:10:04 PM »
Very nice Scott  8),the tank does look like it came out very well;are you pleased with the inside cond.? I know you've been through 'Hell and High water' on CL350 tanks.
I have a set of orig. oem good used grey control cables if you need one.
« Last Edit: September 25, 2016, 01:14:49 PM by grcamna2 »
Offline Scott S
« Reply #95 on: September 25, 2016, 03:14:17 PM »
 Yeah, getting a good tank was a struggle. Finally ended up with two I can work with. One still needs badges and a petcock, but I'll get there.
'71 CB500 K0
'81 Yamaha XS650
Offline CycleRanger
  • No comment about being an
« Reply #96 on: September 25, 2016, 03:49:51 PM »
What did the paint cost?
Offline Scott S
« Reply #97 on: September 25, 2016, 04:13:28 PM »
 The paint itself was $72. The bodyshop charged $300. It's super nice, though. They always do excellent work....and quick turnaround time.
'71 CB500 K0
'81 Yamaha XS650
Offline CycleRanger
« Reply #98 on: September 25, 2016, 06:28:53 PM »
That's not too bad. Is the stripe painted?
Offline Scott S
« Reply #99 on: September 26, 2016, 02:00:04 AM »
 Yes.
 I'm really happy with this shop. Their prices are "fair"....not cheap, but not outrageous...but the quality of the work is well above average and the turnaround time is always very fast. And they're a bunch of really nice guys, too.
'71 CB500 K0
'81 Yamaha XS650
