SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
The
SOHC/4 World Tour
is in under way.
Home
Help
Login
Register
Donate
Tech Forums
SOHC/4 Bikes
Topic:
Charging problem troubleshooting. Rotor test.
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Charging problem troubleshooting. Rotor test. (Read 480 times)
Supersportguy
Full Member
on:
July 06, 2016, 01:42:29 PM »
How can I check the rotor on a 1978 CB550K. My stator is good and so is my field coil, they both ohm out fine. I don't know if the rotor is good. I hate to pull it if I don't have to. I still have to check my Voltage regulator and diode.
Logged
flybox1
My wife thinks I'm a
Really Old Timer ...
Re: Charging problem troubleshooting. Rotor test.
Reply #1 on:
July 06, 2016, 01:45:32 PM »
start here:
http://www.hondachopper.com/garage/troubleshooting_charging_system/troubleshooting_charging_system.pdf
Logged
'78 750K (F3 engine) PD42b's, Modified airbox w/K&N filter, 40/110 jets, 1 needle shim, IMS@ 1 turn out. Kerker + Cone 18" QuietCore
"This is my CB. There are many like it, but this one is mineā¦"
strynboen
Old Timer
Reply #2 on:
July 06, 2016, 02:20:36 PM »
the rotor can not fail..if all ohm is ok..and no shots is faund use heighvolt test..heating all parts to 80 deg..then- regulator- viring- diodes must be thekked...
Logged
i hate all this v-w.... vords
Print
Pages: [
1
Go Up
« previous
next »
Tech Forums
SOHC/4 Bikes
Topic:
