Author Topic: RE: Let's see your garage Art  (Read 10513 times)
Offline BenelliSEI
  • 1969 cb750
Re: RE: Let's see your garage Art
« Reply #50 on: November 19, 2022, 11:37:37 AM »
Love the stain glass!
This original Honda Dealer Sync. Set is probably+50 years old..... Does not work, but cleaned up well. Truly just shop wall art.
Offline BenelliSEI
  • 1969 cb750
« Reply #51 on: November 19, 2022, 11:45:17 AM »
Used this “wall hanging” yesterday. My hydraulic press hangs on two farm gate hinges, screwed deep into the posts that hold up the rest of the barn. The female hinge portion is welded to the press frame. It swings out for use and then stores tight up against the wall the rest of the time, up off the floor, out of the way.
It’s a small unit, that was in the way, sitting on the floor. We had to sit on the floor to use it. Hanging up a few feet off the ground makes a huge difference. One of the “L” brackets is drilled for a safety pin so it can’t jump up and off the mounts. Not really shop art, but everyone that sees it stares at it for a while and then builds their own copy! On Sale a few years ago for $99, one of the best tools I’ve bought. Should have done it 40 years ago!
« Last Edit: November 19, 2022, 11:57:36 AM by BenelliSEI »
« Reply #52 on: November 21, 2022, 03:45:01 AM »
My work desk decoration for many years.
I found it in scrap metal while on internship in a factory. It is a core drilled out of SS valve precast for nuclear power plant.
Later, in my first job, I had it ground smooth.
« Last Edit: November 21, 2022, 03:46:32 AM by 70CB750 »
« Reply #53 on: November 28, 2022, 08:30:17 AM »
 I'm thinking I should hang the stained glass in the living room window with light behind it, my version of a leg lamp. Except I don't want my wife to accidentally break it.
