Author Topic: '70 CB 750K Front Fork Question  (Read 872 times)
Offline major domo
« on: July 07, 2016, 11:02:47 AM »
I'm wondering what holds the chrome trim ring in place (# 20 in attached diagram) on the front forks of a 1970 CB 750? This ring is located just below the headlamp bracket. Parts diagram seems to show rubber donut (part #22 in diagram) just above, but I believe that goes inside the lower part of the headlamp bracket to provide a cushion for the bracket against the lower tripple tree. Thanks in advance!
Offline danyo
Re: '70 CB 750K Front Fork Question
« Reply #1 on: July 07, 2016, 06:51:02 PM »
It's tight fit on gaitor rubber, nothing else holding it. The same ring is used on later models also.
Sent from my SM-N900T using Tapatalk
Offline el pachuco
« Reply #2 on: July 08, 2016, 01:31:26 AM »
Yes   ^^^^^^^^^^^^
Lift the chrome ring as high on the headlight bracket as you can. Then slide the rubber fork boot up onto the headlight bracket and slide the chrome ring down over the top of the rubber boot.
Done!
« Reply #3 on: July 08, 2016, 07:00:41 AM »
The top of the rubber has a groove that will snap in on the headlight ear, then the trim ring drops down a fits on end of rubber
Offline Johnie
« Reply #4 on: July 08, 2016, 10:12:41 AM »
Just keep in mind that gaitor rubber has a top and bottom. The drain holes in the gator should face down if you replace it.
« Last Edit: July 08, 2016, 11:06:38 AM by Johnie »
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline major domo
« Reply #5 on: July 08, 2016, 10:23:36 AM »
Thanks for all the tips!  The "70 CB 7ho should be completed soon, and I'll post photos.
Offline rhackney
« Reply #6 on: July 08, 2016, 12:59:38 PM »
I hated wresting with these F#$%ing things.
Then I found this video: https://www.youtube.com/watch?v=NSYlmjMo30g
Now my forks look great!
THANKS YOUTUBE!!   ;D
