Author Topic: Thrust bearings (or lack of..) crank & cases.  (Read 1134 times)
Offline Ilja
« on: July 09, 2016, 03:56:36 AM »
Did anyone else encounter worn thrust surfaces when rebuilding a cb750 engine?
Newer engines have thrust bearings, but the ol' cb just has a machines surface where the crank runs into.
Mines a bit grinded...
Also the crank bearing shells are a little bit worn... only one in the engine that shows significant wear.
