Poll
Which do have or would choose and why?
Pamco
5 (21.7%)
Dynatek
8 (34.8%)
Hondman
10 (43.5%)
Total Members Voted: 23
Voting closed: July 29, 2016, 05:12:13 PM
Author Topic: Electronic Ignition  (Read 8298 times)
Offline 550Resto
Electronic Ignition
« on: July 09, 2016, 05:12:13 PM »
I'm looking at electronic ignitions and want opinions and pros and cons that people have had. My current ride is a 1978 CB550.
I've seen the Hondaman ignition and was leaning towards that, but am open and eager to hear others opinions.
Offline dusterdude
Re: Electronic Ignition
« Reply #1 on: July 09, 2016, 10:07:52 PM »
Pamco
Sent from my LG-D850 using Tapatalk
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline gtmdriver
« Reply #2 on: July 10, 2016, 12:14:30 AM »
I'm using the Boyer Bransden and I'm more than happy with that.
Offline Old Moe Toe
« Reply #3 on: July 10, 2016, 12:28:21 AM »
Bloke I know has burnt out two dyna 3 ignitions on his Honda. Just put Hondamans on my KO and am happy with it.
Have a dyna 3 on my old moto guzzi and it made a big difference and is still going strong.
Am no expert but I have not heard any bad wraps about the Pamco's.
Offline flatlander
« Reply #4 on: July 10, 2016, 01:38:15 AM »
i'm also using boyer-bransden and it's working well. had some trouble with water getting to the electrical connections of the coils but since i sealed them better, it's all good.
i thought once i go electronic i might as well go all the way and get rid of the mechanical advancer as well. that's why i did not go for a "hybrid" like pamco or hondaman.
Offline separatist
« Reply #5 on: July 10, 2016, 02:22:39 AM »
Dyna S on my 74 CB550, never a glitch and still running strong after 11 years.
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
« Reply #6 on: July 10, 2016, 02:58:05 AM »
Anyone have a cycle-x?
Offline Scott S
« Reply #7 on: July 10, 2016, 03:27:16 AM »
 Pamco on six SOHC4's and four XS650's and never had a problem.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
« Reply #8 on: July 10, 2016, 08:52:44 AM »
Old coils might be too old too? New Dyna 5 ohms (black) with Hondaman ignition that also need a std Point plate.
I have NO problems with the mechanical advancer after tightening the sloppy springs that advanced way too early. This was with Pamco that blew the electronics on 2-3 due to problems with crappy ultimate coils shipped with the set.
Tightened the springs by cutting each 1/2 wound and it ran good with next ignition, Dyna-S with Dyna 3 ohm coils. This setup drained the battery within an hour test drive so I returned them and got 5 ohms instead. No problem except for my lost trust for the electronics. I ordered Hondaman ignition and NOS TEC plate from Jtmarks77. Ran it as OEM for 200km, then Hondaman ignition on.
The ignition works well from idle to 10.000rpm and probably more....
Now no condensers. I'll add them just for sure abd see if something will change.
« Last Edit: July 10, 2016, 08:54:39 AM by PeWe »
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #9 on: July 10, 2016, 09:40:18 AM »
I've got the C5 (Powerarc) multi spark ignition and love it.
The performance difference on my bike where immediately noticed.
Previously had Pamco and Dynamic ignitions.
Offline tweakin
  • tear down
« Reply #10 on: July 10, 2016, 10:00:36 AM »
+1
  • Holy Cow! I'm a
« Reply #11 on: July 10, 2016, 10:42:36 AM »
Cool thanks!
I was curious about those.
Is it a plug n play setup or does it have to go to a dyno tuning shop for mapping?
Offline flatlander
« Reply #12 on: July 10, 2016, 01:39:07 PM »
jimmy, do you have a dyno comparison of the powerarc with the other ones you had?
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #13 on: July 10, 2016, 02:58:50 PM »
Cool thanks!
It's pretty much plug 'n play. The advance curves (selectable) are preprogrammed.
The only complaint is setting static TDC timing. Without the factory advancer TDC must be located using a piston stop and degree wheel. Once set, everything works like a charm. Sorry, no dyno graphs to share. Set of the pants dyno IA all I've got.
Bike ran considerably stronger in midrange and idles perfectly.
  • Holy Cow! I'm a
« Reply #14 on: July 10, 2016, 03:13:56 PM »
Cool thanks!
Small price to pay for hi tech ign
Not having seen a cycle x unit - Would there be any feasible way of keeping a 1/4 t.f mark with the install?
« Reply #15 on: July 10, 2016, 04:45:24 PM »
Moe, a few years back, Dyna had a bad batch of ignitions, lots of failures, they seem to have fixed the problem now....
Offline andyvclifford
« Reply #16 on: July 10, 2016, 04:46:00 PM »
I think it really depends on what makes the most sense for you.  My entire points were shot from the points themselves to the condensers so Honda mans unit wasnt really the best idea for me since Id have to also buy new points so I went with Pamco.  That being said I am 100% going to put Hondaman's unit on my 750 F that has good working stock points and condensers!
Offline Big Red
« Reply #17 on: July 10, 2016, 09:14:15 PM »
Hello,
I have the Power Arc ignition and I love it. It has a user freindly web page associated with it from the manufacturer, and you can tune the advance as you see fit. It is not the top of the line programmable version however.
I would recommend it.
Thank you.
Chris
1978 CB750 Brat
Offline Bailgang
  • Scott
  • Indiana
« Reply #18 on: July 11, 2016, 06:51:00 AM »
Same here but it's only been in the bike for a bit over a year now so way too soon for a long term evaluation, the only issue so far is that I'd like to use a rev limiter with it and so far it's unclear if one will work with it and I haven't gotten a response back from BB about it. It's advance curve is set so there's no adjustability to it but my F2 doesn't seem to mind it. I'm glad to see this hasn't turned into a debate as to which electronic ignition is better because there are actually quite a few to choose from and which one is better for you really depends on what you're expecting it to do and how much you're willing to spend. It would be nice to see a comprehensive comparison of all of them that are available but that would take quite a chunk of $ to purchase all of them not to mention the cost of the dyno time needed to test them all, not just to test any performance gains but see what kind of load each puts on the bikes charging system.
Scott
71 cb350 twin
77 cb750 F2
83 gl1100 Interstate
Offline flatlander
« Reply #19 on: July 11, 2016, 07:40:47 AM »
boyer can programme a rev limiter or also custom curve into their units. of course that's easiest before they ship it to you otherwise you have to send it in to them...
Offline 540nova
« Reply #20 on: July 11, 2016, 09:26:45 AM »
I had a Pamco which lasted 80 miles. Getting a refund, going to Charlie's Place. Hope I have better luck with it.
« Reply #21 on: July 11, 2016, 04:45:36 PM »
From hundreds of units used here, thats the first Pamco failure i've heard of, Peters service is second to none, I would certainly use one of his units....
Offline 540nova
« Reply #22 on: July 11, 2016, 05:21:48 PM »
Retro Rocket, you have GOT TO BE KIDDING. Google Pamco Ignition Problems, there are dozens upon dozens of complaints about this unit. To his credit, Pamco Pete is an honorable person, who it seems, refunds or exchanges without question, but this unit seems to have a very rocky reliability record. Seeing how long you've been a forum member, I find it hard to believe this is the FIRST problem you've ever heard.
Offline 540nova
« Reply #23 on: July 11, 2016, 05:23:10 PM »
Offline 540nova
« Reply #24 on: July 11, 2016, 05:25:04 PM »
