Author Topic: Torque specs  (Read 1133 times)
Offline mickey_7106
Torque specs
« on: July 11, 2016, 06:49:01 PM »
anyone know what the torque specs are for the circled bolts in the pic? the owners manual I'm using doesn't state anything
Re: Torque specs
« Reply #1 on: July 11, 2016, 07:18:55 PM »
Did you download the service manual available (for free) here?
Offline mickey_7106
Re: Torque specs
« Reply #2 on: July 19, 2016, 04:55:02 PM »
i downloaded the workshop manual for my cb400f. I've gone through the whole thing. did i miss it?
Offline DaveBarbier
Re: Torque specs
« Reply #3 on: July 21, 2016, 12:31:26 PM »
Those are just small 6mm bolts. Not sure if there's an actual torque spec but I've heard people doing about 8-10 ft/lbs. It's steel threading into aluminum so don't over tighten it. I used blue loctite on those when I put my engine back together.
Re: Torque specs
« Reply #4 on: July 21, 2016, 12:34:32 PM »
10 seems slightly high for 6mm. 7 - 8 ??
Re: Torque specs
« Reply #5 on: July 21, 2016, 12:37:54 PM »
hand tight with a short-handled box wrench and a +1 for blue locktite.
For 6mm bolts, 8ftlbs (especially w locktite) is about the max you should go.
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
Re: Torque specs
« Reply #6 on: July 22, 2016, 06:37:14 AM »
--Evan
1975 CB750K "Rhonda"
Offline mickey_7106
Re: Torque specs
« Reply #7 on: July 26, 2016, 06:18:25 PM »
thanks guys! btw where did you find that chart?
Offline evanphi
  • Apparently I'm an
Re: Torque specs
« Reply #8 on: July 27, 2016, 04:54:51 AM »
Shop manual.
Link in my sig. You can search the PDF with Ctrl+F. :)
--Evan
Offline mickey_7106
Re: Torque specs
« Reply #9 on: July 29, 2016, 08:31:59 AM »
Thanks!
Shop manual.
