Author Topic: Turn Signal Not flashing beyond Range A - 1976 CB750F  (Read 527 times)
Offline Bristledisk
« on: July 11, 2016, 07:15:13 PM »
The user manual states when turn signal switch is moved within range A (slightly each side of centre position) , the turn signal flashes. This works correctly on both Right and Left signals and the signal flash.
When moving the switch beyond this range the turn signal should flash and the warning buzzer sounds.
However what happens is the signal stop flashing and I hear no buzzer on both Left and Right. I have heard the buzzer occasionally. Any ideas? I've sprayed the switch inside with electrical contact cleaner.
1977 CB400F, 1976 CB750F1, 1974 CB550K, 1975 CB550K, 1976 CB550K2, 1973 CB350F
Re: Turn Signal Not flashing beyond Range A - 1976 CB750F
« Reply #1 on: July 11, 2016, 07:38:55 PM »
You may have a shorted buzzer. Try unplugging it to see if the lights work correctly then?
Offline b52bombardier1
« Reply #2 on: July 11, 2016, 07:55:32 PM »
My guess is a bad ground or a dirty connector.  Try a temporary supplemental ground wire and see if things flash better.
Rick
1971 School Bus Yellow Aermacchi H-D Sprint 350
1972 Candy Yellow CL100 K2
1972 Candy Jet Green Honda CB500
1973 Mighty Green ST90 K0
1974 Mars Orange CT90 K5
1975 Topaz Orange ST90 K2
1976 Shiny Orange CT90
2006 Honda Foreman 500 (restored)
Offline SamP
« Reply #3 on: July 12, 2016, 04:55:03 AM »
Another user has a similar issue - signal would flash if half pushed, but not fully pushed. Found the problem in the wiring.
http://forums.sohc4.net/index.php/topic,154530.0.html?PHPSESSID=8b16m7ln90hrv364uh724augm0
Sent from my LG-H811 using Tapatalk
Offline Bristledisk
Re: Turn Signal Not flashing beyond Range A - 1976 CB750F - Working but...
« Reply #4 on: August 27, 2016, 03:24:39 PM »
So I disconnected the wires connected to the buzzer inside the headlight shell as suggested and the turn signals now both work correctly in the full on position.
Why would disconnecting the buzzer make the turn signals work? Does this suggest the buzzer is not grounding correctly?
