Author Topic: lower 750 engine case compatibility  (Read 1837 times)
Offline nteek754
  • 1973 K3/750/836/70 1970 750 chopper 1973 cafe
« on: May 31, 2005, 06:35:34 AM »
Hey all in my last post about remote oil filter because of a wasted  threads for the oil filter/canister well I now am looking to replace the bottom case and  wonder if I just get another 1978 case if they are an automatic match or are there other differances thanx for any input  Craig
seven fifty four ever its not the destination its the journey Ive been collecting these old dinasours for 33 years . they are quite an ICON
Offline Bob Wessner
  • "Carbs Suck!"
Re: lower 750 engine case compatibility
« Reply #1 on: May 31, 2005, 07:05:20 AM »
It's my understanding that the upper and lower cases are matched during the production process. The mating surfaces are machined to match that is. I don't believe upper and lowers are compatable from different engines without some serious work that I'm not sure most can perform.
« Reply #2 on: May 31, 2005, 07:49:53 AM »
You will need the matched set. You can get away with swapping uppers and lowers (most of the time) on new engines but that's about it.
Offline Tim.
  • www.DOTHETON.com
    • DO THE TON
« Reply #3 on: May 31, 2005, 07:53:38 AM »
You might consider repairing and using one of these:
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=4553506609
So you don't have to use the repaired threads any more.
Roule comme dans les annĂ©es 70...   Roll as in the Seventies...
