Author Topic: Chain master link broke, help me diagnose the damage  (Read 2813 times)
Offline WaxhawFive
  • 1975 CB550F Super Sport
« on: July 12, 2016, 11:28:55 AM »
The master link failed this morning on my first ride to work, and I had to push it ½ mile back home.  Supposedly it’s a new chain, but maybe the P.O. didn’t have the clip fully seated, and I failed to notice it when I cleaned, oiled, and checked the tension this weekend.  I’m just thankful it didn’t happen on the ride last night with the wife!   The damage could have been worse I suppose, have a look.
Offline WaxhawFive
Re: Chain master link broke, help me diagnose the damage
« Reply #1 on: July 12, 2016, 11:29:40 AM »
More pics...
Offline WaxhawFive
« Reply #2 on: July 12, 2016, 11:29:53 AM »
More
Offline WaxhawFive
« Reply #3 on: July 12, 2016, 11:34:15 AM »
I found the main half of the master link and the spring clip inside the greasy cover.  Both ends of the chain look fine, no damage, so I ordered a new 530 standard (non O-ring) master link and hopefully I'll be back in business.
Offline WaxhawFive
« Reply #4 on: July 12, 2016, 11:49:37 AM »
How serious is this damaged area, other than making a mess from throwing grease out?  I guess I could clean it all up and JB-Weld the two pieces I found back in place?  I'm glad no wires were touched.
« Reply #5 on: July 12, 2016, 12:27:00 PM »
Clean de-grease that area really well.  Start it and check for leaks while its idling.
Offline WaxhawFive
« Reply #6 on: July 12, 2016, 12:35:17 PM »
OK, I'll do that tonight and report back.
Offline Scott S
« Reply #7 on: July 12, 2016, 12:37:35 PM »
 Looks like you got lucky!
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
« Reply #8 on: July 12, 2016, 12:51:34 PM »
Yes you got lucky...
Offline WaxhawFive
« Reply #9 on: July 12, 2016, 01:17:48 PM »
What's the large black rubber disc?  Is that some sort of hole plug?
« Reply #10 on: July 12, 2016, 01:30:50 PM »
Yes, and it gets eaten quickly when the wrong chain is used.
Offline WaxhawFive
« Reply #11 on: July 12, 2016, 01:41:27 PM »
OK, I'll check it for leaks.  If not I'll probably go ahead replace it at the next oil change anyway.
Offline Scott S
« Reply #12 on: July 12, 2016, 02:07:19 PM »
 No....leave the big rubber plug alone. I don't see any reason to mess with it unless it was damaged by the chain.
'71 CB500 K0
'81 Yamaha XS650
« Reply #13 on: July 12, 2016, 02:17:49 PM »
It is/was.
The question now is if it is leaking.
I think itll be OK, but the bike should be run to test it.
Ive seen much worse here over the years  ;D
Offline Scott S
« Reply #14 on: July 12, 2016, 02:43:39 PM »
 Me too....that's why I said leave it alone!
'71 CB500 K0
'81 Yamaha XS650
« Reply #15 on: July 12, 2016, 03:47:56 PM »
Just be sure you install the master in the proper direction.
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #16 on: July 12, 2016, 04:29:52 PM »
Yup. Got real lucky I'd say.
The plug looks like it will live to see a few more miles.
You could cut a thin piece of sheet aluminum and JB Weld it in to keep grease and grim off the oil pump.
Offline Kevin D
  • SE Michigan
« Reply #17 on: July 12, 2016, 06:04:27 PM »
I can't quite tell, but in the first picture those sprocket teeth look like they are hooked/worn.
71 CB750 K1
104,000 miles
Original Owner
———past———
70 SL100/125/150
70 Candy BlueGreen CB 750 K0
« Reply #18 on: July 12, 2016, 06:24:37 PM »
[/quote
That front sprocket is toast. It may have contributed to the link failure. None the less, it needs to be changed pronto.
Offline WaxhawFive
« Reply #19 on: July 13, 2016, 05:17:37 AM »
No time for cleaning last night, but I started it and no leaks from anywhere.  I'll order a new front sprocket today.  Any brands to avoid, or recommended?
Offline WaxhawFive
« Reply #20 on: July 13, 2016, 05:46:28 AM »
Any tricks to getting these sprockets off?  It looks like I need to flatten a few tabs, then two bolts.  Looks simple, but...
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #21 on: July 13, 2016, 05:50:40 AM »
remove the bolts (keep it in gear), flatten the tabs, and then it will slide off. You'll have to slightly rotate the washer to take it off.
--Evan
1975 CB750K "Rhonda"
Offline pmanning
« Reply #22 on: July 13, 2016, 05:58:40 AM »
It is simple.  The bolts come off, the keeper rotates a few degrees and slips off the splines, then the sprocket slips off.  Check the rear sprocket as well.  If teeth are worn and hooked on your countershaft sprocket they are likely no better on the wheel sprocket.  New chain on worn sprockets is no good.
« Reply #23 on: July 13, 2016, 06:54:36 AM »
JTsprockets and Sunstar have good products.
Offline WaxhawFive
« Reply #24 on: July 14, 2016, 09:50:21 AM »
I ordered a JT, it'll be here tomorrow.
BTW, what is the correct way?  Mine had the spring clip towards the wheel, and due to my limited damage when it failed, I'd think that was the "right" way.  Is that correct?
