Author Topic: Leaky bowl  (Read 401 times)
Offline Ereyer
Leaky bowl
« on: July 13, 2016, 04:58:49 AM »
Hello all:
Attached carbs after rebuilding them and carb two leaks like a sieve. What are the float level specs on keihin carbs for a cb 550f (1975)?
Eric
Offline greenjeans
  • 1972 CB750K2
Re: Leaky bowl
« Reply #1 on: July 13, 2016, 05:20:57 AM »
More likely it's the float needle and seat.
Offline CBGhia
Re: Leaky bowl
« Reply #2 on: July 13, 2016, 05:33:32 AM »
Did you try tapping the bowls with a screwdriver handle?
Pretty sure the manual says 22mm for the early 550.
Offline Ereyer
Re: Leaky bowl
« Reply #3 on: July 13, 2016, 05:49:49 AM »
Meh. I'm mad at myself. I installed new needles and seats. I will try knocking on the float bowl first before tearing it out again.
Thanks!
Re: Leaky bowl
« Reply #4 on: July 13, 2016, 06:45:35 AM »
Thanks!
Please verify your fuel height using the clear tube test.  Aftermarket float valve size often differs from OEM as seen below from the carbs I recently worked on.  Your stock float height is just a starting point.  Adjust to achieve the proper fuel level.
