Author Topic: PowerArc with Motogadget Motoscope problem  (Read 5150 times)
Offline h.lanooy
« on: July 14, 2016, 02:44:08 AM »
Hi there,
I'm building a CafeRacer from a CB650 (1981).
The build is pretty far. I have a lot of Motogadget stuff like mUnit, mLock an Motoscope Pro.
All working fine.
I just recently replaced the stock ignition with a Power Arc Ignition system. The Power Arc works with optics timing, more accurate than Hall effect (magnets).
It also delivers 3 sparks per compression stroke. Cleaner fuel burn.
The ignition module has a dedicated tach trigger wire. This wire will give 1 signal per rotation (if you draw the signal from the coil you'll get 3 signals because of the 3 sparks).
If I hook this trigger wire to the Motoscope, the Motoscope won't react or process it. Tach does nothing.
If I hook up a induction signal pick up, this works, but still registers 3 signals instead of one.
If I hook up the green trigger wire form the ignition to another tach (ZXR400) it works like a charm.
Together the systems won't work. Motogadget replies to me that it's a compatibility problem. Advise to use the inductive signal pickup. Problem is the 3 sparks before mentioned.
My reply was what are the criteria to be met to be compatible....
If figured, I can't be the only person who has a Power Arc system and Motogadget tach.
Anyone out there knows anyone, who knows anyone that got these working together? It must have something to do with the signal I guess.
Hope someone can provide some help.
Kind regards,
Herbert.
Offline h.lanooy
Re: PowerArc with Motogadget Motoscope problem
« Reply #1 on: July 14, 2016, 05:57:24 AM »
Thanks for the reply Calj737,
My system is also from C5. Plug wires are supression type (moroso 8mm).
Also using resistor plug caps.
Both Paul (C5) and Gary (PA) never came across this problem before.
Both take time to come up with solutions.
The induction pick up mainly used for cdi picks up the 3 sparks.
Can't find the right setting for it to give the correct rpm reading.
What impE and impF did you use on the chronoclassic?
Did you hook your chronoclassic to the PA green wire tach trigger?
Or did you use the motogadget induction signal pickup?
Offline h.lanooy
« Reply #2 on: July 14, 2016, 07:01:37 AM »
So you did not use the pa module green tach pulse wire?
To which wire of the coils did you connect the chrono's yellow wire?
What type coils does your c5 system have? My set has the newer mc2 coils. If I connect the motoscopes yellow wire to the yellow coil wire, that coil gets overheated.
I asked motogadget what the requirements are for the signal to be compatible. Still waiting for their reply.
But if have three sparks, you must have made adjusments in impE and impF for it to work correctly.
Could you please check your settings and post it here?
Thanks again!
Offline h.lanooy
« Reply #3 on: July 14, 2016, 08:34:30 AM »
When I tried your type of setup, no mather which coil, it gets overheated.
Can you recall not using 1 as your impE?
If I use impE "1" I definitely get too high rpm values. If I use 3 it's still not right. This is by using motogadget's signal pick up.
I'll keep trying different settings.
When you have access to your bike in the future please check the settings and let me know. There's a chance I won't find the correct settings.
Offline h.lanooy
« Reply #4 on: July 14, 2016, 09:33:11 AM »
The coil gets overheated.
I connected the yellow motoscope wire (tach trigger) to the yellow coil wire (trigger / negative side).
I could try making the connection to the black or white wire coming from the module and not the yellow from the coil.
« Reply #5 on: July 14, 2016, 09:26:56 PM »
This is pure marketing hype, as fabricated as the animation they use to "prove" it.
Offline h.lanooy
« Reply #6 on: July 15, 2016, 09:34:01 AM »
Problem is identified.
I hooked up the trigger wire from the PA module and the trigger form the induction signal pick up.
When cranking the engine you can instantly see the difference.
Both signals have a 12V strong signal.
The trigger of the PA module drops to about 2V to 3V (never hits 0V!!)
The trigger from the induction signal pick up hits 0V.
With this knowledge I came to the conclusion that this is the only difference why one signal works with the Motoscope Pro and the other doesn't.
I only need to make the trigger from the PA module hit 0V when it pulses.
I tried this with a pull down resistor. I had 3 sizes, 10 kΩ, 4,7 kΩ and 1 kΩ.
Only the 1 kΩ gives a result. The tach from the motoscope reacts to the PA module's trigger!!!!!!!!
But it seems 1 kΩ is too small so the 12V sips away and the signal never reaches the Motoscope in about 5 seconds after cranking.
But the source of the problem is identified!!! I'm closer to the solution.
Offline h.lanooy
« Reply #7 on: May 06, 2019, 02:03:52 PM »
It has been a very long time, but problem fixed around time I started this post.
The solution for me came from help on a circuits forum. Someone came up with the diagram underneath. It works (on this date at least 2 years).
I hope in someway anyone running into the same problem is helped by this.
