Author Topic: How to pry cylinder head off the right way?  (Read 2970 times)
Offline juntjoo
« on: July 14, 2016, 11:52:15 AM »
I think I'm doing this wrong and I don't want to get in the habit of scuffing things up. Actually I want to get OUT of the habit. I've got all the bolts out of the threads.
It's not really budging. Are there bolts I'm missing? I only see the obvious ones holding it down.  Do I just need to find one spot and plan on it to be the pry point I always abuse and just hammer away at it? As you can see I'm currently using to steak knife cause it's thinner than my standard pry tools. I must be missing some bolts or there is some trick I'm unaware of. Please enlighten...
« Last Edit: July 14, 2016, 11:55:19 AM by juntjoo »
-Ben
82 Nighthawk 650..
1982 Honda Nighthawk...
I HAVE A 1982 HONDA NIGHTHAWK FFS! j/k. It's my only bike, my first and last.
Offline Bankerdanny
  • Endeavor to persevere
Re: How to pry cylinder head off the right way?
« Reply #1 on: July 14, 2016, 12:25:26 PM »
I don't think I would separate the head that way. You are just asking for a major scratch. I would use a dead blow hammer to loosen the head.
« Reply #2 on: July 14, 2016, 12:33:08 PM »
^+1
Heat, tap, repeat
Offline Phinn
  • Subversive
« Reply #3 on: July 14, 2016, 12:37:01 PM »
How many bolts did you find and remove? Counting them is the only way I know of to determine if you got them all.
1978 CB750K -- "Mouse," a former basket case, resurrected
Offline bochnak
    • How-To Motorcycle Repair Blog
« Reply #4 on: July 14, 2016, 12:38:47 PM »
Dead blow over and over again. You can hit the cooling fins it you hit them straight on, never on an angle.
What year and model?
Offline juntjoo
« Reply #5 on: July 14, 2016, 01:28:50 PM »
Ah ha! I only counted 12 but there's 13
Thanks guys. If removing this 13th bolt doesn't do it the heat then hammer method should work. I've actually done that on a car years ago. Just forgot that method. Thanks
-Ben
82 Nighthawk 650..
Offline chewbacca5000
  • I polish covers!
« Reply #6 on: July 14, 2016, 01:36:19 PM »
Taking that last bolt off the valve cover/rocker box should pop up and come off.
Offline juntjoo
« Reply #7 on: July 14, 2016, 01:40:04 PM »
82' 650
-Ben
82 Nighthawk 650..
Offline juntjoo
« Reply #8 on: July 14, 2016, 02:55:27 PM »
What are these called? Two on each side that look like they only help secure the head laterally.
I imagine they're nice and seized up in there. Anyway, so I've been torching in and around there but after smelling burnt rubber I don't know if I should trust my method. Maybe my torch is too fat or I'm just not careful enough
-Ben
82 Nighthawk 650..
Offline juntjoo
« Reply #9 on: July 14, 2016, 03:06:15 PM »
You mean like this?
When you said that I wasn't sure what you meant as there is no spot to hit strategically on those fins anywhere  to break the connection. Anyway, you should've said 'do NOT hit them' so I would've made sure not to but I guess I'm clumsy and I hit it anyway. These sand filled type hammers, only ones I have besides a regular hammer don't seem to work.
Any other ideas anyone?
-Ben
82 Nighthawk 650..
Offline juntjoo
« Reply #10 on: July 14, 2016, 03:09:32 PM »
You mean these?
I need another suggestion. I'm at that point I always come to where my monkey brain, perhaps the majority of it lol, is tempting me pick it up and throw it on the ground, to get it off AND to teach it not to test my patience. Ideas please  :P
-Ben
82 Nighthawk 650..
  • I polish covers!
« Reply #11 on: July 14, 2016, 03:36:14 PM »
You mean these?
yes those should be them.  Sorry about the chip.  The sand filled hammer is also known as a dead blow hammer used for driving out bearings and races.
Pretty sure the other posted meant rubber mallet.  I would at this point take a deep breath and give go do something else for a bit.  Just give it a little rest.
« Reply #12 on: July 14, 2016, 03:52:22 PM »
First pic right below the top cover, that I don't understand. Why it is there.?
Just below that..great place to tap, it must go upward.. Do not use excess hammering. Force.
If at this point you did not know there is dowels, good times to quit and start reading the manual..
Offline cb650
« Reply #13 on: July 15, 2016, 12:27:54 AM »
Thats not the head.  Cam cover.   the rocker covers should be off and have the valves all loose.  AND there are a 4 bolts under the center.  If I remeber right there are 22 of them.
Offline flatlander
« Reply #14 on: July 15, 2016, 01:56:58 AM »
that's the best piece of advice so far.
and please put a piece of wood or something between the hammer and the head before battering it further.
« Reply #15 on: July 15, 2016, 06:44:07 AM »
Looks like he is right, it's just he rocker cover he is trying to get off.
Why are the top covers still in place?   ?
Chalk this one up to, the cost of...trying to getting in the engine without having or reading the manual...
Offline bochnak
« Reply #16 on: July 15, 2016, 07:08:49 AM »
You mean like this?
No, I apologize, that is not what I meant. I should have been more specific.
