Author Topic: RE: Rod bolt tighenting?  (Read 742 times)
Offline chewbacca5000
  • I polish covers!
« on: July 14, 2016, 01:07:39 PM »
I do not have any fancy tools to measure stretch or in lbs.  Can someone recommend a tool to do this?  Maybe I should just take it to the machine shop?
Re: RE: Rod bolt tighenting?
« Reply #1 on: July 14, 2016, 03:43:09 PM »
Micrometer. Most guys probably just torque them and call it a day. I'm one of those 'low tech' guys LOL.
« Reply #2 on: July 14, 2016, 03:51:55 PM »
I use a micrometer and a ball bearing in the dimpled end of the CARR bolts. Take your time and measure the bolts first & jot it down. I always torque to spec first than "adjust by stretch" Bit goofy with the bearing but it's the only way I could think of without a proper guage.
  • I polish covers!
« Reply #3 on: July 14, 2016, 04:16:26 PM »
Thanks guys!  I think I am leaning on just paying to have the whole assembly as it is worth the peace of mind.  I will only be doing this one anyhow.
I talked to my machine guy and he said he could torque to inch pounds.  Not sure he is going to bother with torque measure, torque measure which seems to be the right way to do things.
Other poster have said the lightened crank is worth it so mine as well get the whoe shabang at once and be done with it.
« Reply #4 on: July 14, 2016, 05:20:47 PM »
 I did stretch on a chevy race engine and I went so far past the torque spec it was scary. Never had a problem though.
  • I polish covers!
« Reply #5 on: July 14, 2016, 07:38:47 PM »
That had to be nerve wracking to say the least.  If the purpose of buying HD rods / bolts is peace of mind maybe I should just leave this one to the pros.
Online PeWe
« Reply #6 on: July 15, 2016, 01:02:37 PM »
These rod bolts can be torqued and stretched more than once?
