Author Topic: 1978 CB750 - Re-born a 836cc Wiseco JMR Ported Hot Rod  (Read 34384 times)
Offline Ericcb750
Re: 1978 CB750 - Re-born a 836cc Wiseco JMR Ported Hot Rod
« Reply #150 on: February 16, 2017, 07:10:05 AM »
OH Man, that looks awesome!!!  I have a butt load of VHT high temp ceramic paint and duplicolor at the house but with the bike I'm building I would rather spend a bit more and not have to worry about chipping/flaking cheaper paint.
The issue I'm wondering about is the head and cylinders have already been cleaned up on the gasket surfaces, the cylinder is all bored/honed for the Wiseco's..
Cal, On yours did you get it powdered before doing the bore / hone ?
1978 CB750K
1978 CB750F super sport
2005 Sportster 1208
Offline Ericcb750
« Reply #151 on: February 16, 2017, 07:11:37 AM »
my bad , I just saw you said "after Milling".
What brand did you use on your head? All three of those look amazing.
1978 CB750K
2005 Sportster 1208
Offline calj737
  • I refuse...
« Reply #152 on: February 16, 2017, 09:41:38 AM »
The head and jugs on all my wire cooled bikes is a professionally applied Thermal Dispersion coating. Same guy who does my powder, ceramic, DFL coatings; Andy Vaughan of Thermal Tech in Hopewell, VA. Awesome guy, great service, reasonable pricing. He does NOT do Vapor Blasting. Besides, next to Nils, everyone else is 3rd best  :)
Offline BLAC
  • An espresso is a
« Reply #153 on: February 16, 2017, 10:05:06 AM »
You are using the M-unit to wire cool your motor now!  you have taken it to the next level, sir!
Thanks for the info, I had not heard about that treatment, I'll ask around in LA!  Do you think that finish would suit itself for the fins to be block sanded or do you think it should be left alone?
If you can't fix it with a hammer, it's an electrical problem... If it's an electrical problem, it's Cal's problem.
*2005 Yamaha R6 (sold)
*2014 Ducati Streetfighter 848 (sold)
*2014 BMW S1000RR (sold)
*2010 Ducati Streetfighter S
*1978 CB550 Restomod Build
*1974 CB550 Monoshock build
http://forums.sohc4.net/index.php/topic,154614.0.html
Offline calj737
  • I refuse...
« Reply #154 on: February 16, 2017, 10:48:22 AM »
Sanding the fins afterwards won't effect the finish or effectiveness.
Offline Ericcb750
« Reply #155 on: February 16, 2017, 08:08:45 PM »
I'll check to make sure this uploads correctly, then post more..... This is what of the coolest things i've ever seen....These parts were not destroyed but were not in nice shape either. Nil's is the freakin man!!! Been super helpful throughout the entire process (and patient) haha. Took me a while to get these out to him but let me say, I am 120% glad that I did and I haven't even seen them in person yet.
If this photo shows up alright, i'll post up more .
1978 CB750K
2005 Sportster 1208
Offline Ericcb750
« Reply #156 on: February 17, 2017, 12:24:22 AM »
I'm so pumped for this, just amazing work Nils puts into these...a couple more
1978 CB750K
2005 Sportster 1208
Offline Ericcb750
« Reply #157 on: February 17, 2017, 12:32:02 AM »
Cases, oil pan, covers.... The carbs look amazing and i sent along the full linkage and choke linkage too so everything will have that nice finish....
1978 CB750K
2005 Sportster 1208
Offline BLAC
  • An espresso is a
« Reply #158 on: February 17, 2017, 12:32:52 AM »
Beautiful!
Offline Ericcb750
« Reply #159 on: February 17, 2017, 12:51:19 AM »
He has a set of beautiful Koni 7610 - Aluminum bodied shocks that are getting done up while they're out there too...They;re going to look so f'ing sweet after this..... I'll keep you fellas posted on the build / info. Thanks again for all the help and support along the way.....This forum is still the BEST!
1978 CB750K
2005 Sportster 1208
« Reply #160 on: February 17, 2017, 04:17:50 AM »
OK.....you got the parts....now get busy! ;) ;D
Offline Ericcb750
« Reply #161 on: February 17, 2017, 05:29:00 AM »
You Bet Mike!!! This stuff has all been a long time coming. Once I get the parts back from NIls, Im going to toss the lower case into the engine stand and give all these awesome parts a nice cozy introduction to eachother in those clean engine cases.....
Will read through my manuals/hondaman's book to make sure i don't miss any steps but i'll start by putting that pesky Kickstarter mechanism back in.....
This motor should be amazing with all the new tensioners, HD Chains, clutch, balanced crank, rods, and topped off with that sweet Stage 2+ head and Webcam 63A .,... This baby is really going to sing!!!
1978 CB750K
2005 Sportster 1208
« Reply #162 on: February 17, 2017, 06:36:14 AM »
Wow, Nils! Blown away again!
I just saw that Carpy is getting into vapor blasting. Although more local, I'd still send out to Nils given his track record of performance and customer service.
Offline slikwilli420
  • Master of Disaster
« Reply #163 on: February 17, 2017, 06:48:50 AM »
But Don, Carpy invented the cafe racer movement in America and we all owe him everything for that.
Offline joeyvans
  • Definitely not a
  • God's Country, Earth
« Reply #164 on: February 17, 2017, 06:48:55 AM »
Customer Service is a lost art these days. For most things, I will happily pay more for good customer service!
1976 CB550 K2
Non-SOHC4 - 1974 CB450 K7
Non-SOHC4 - 1996 VFR750F
"No matter how much you shake and dance... the last three drops go in your pants."
Offline BLAC
  • An espresso is a
« Reply #165 on: February 17, 2017, 09:11:52 AM »
 ;D ;D
« Reply #166 on: February 17, 2017, 09:33:27 AM »
Carpy invented vapor blasting. ;D
Offline Ericcb750
« Reply #167 on: February 17, 2017, 09:45:06 AM »
Nils has been the best Since I first contacted him about this project. He's always been helpful even creating and sending me a video about the "dykes" and removing my kickstarter pin....ha-ha.
Always quick to reply and encouraging, and the guys work is just absolutely flawless. I will recommend anyone to go to him, I can't wait to see those Koni's when they're done....with the aluminum bodies all vapor blasted and the black springs.... going to be sick.
I've never dealt with Carpy on anything., seems like he knows his stuff but alot of his stuff is just not my style.
1978 CB750K
2005 Sportster 1208
Offline joeyvans
  • Definitely not a
« Reply #168 on: February 17, 2017, 10:05:18 AM »
As in, you don't wear a pompadour, rolled short sleeves and jeans?
1976 CB550 K2
Offline BLAC
  • An espresso is a
« Reply #169 on: February 17, 2017, 10:28:39 AM »
I just imagine Carpy walks around snapping his fingers asking people if they are Sharks or Jets.
« Last Edit: February 17, 2017, 11:47:29 AM by BLAC »
Offline Ericcb750
« Reply #170 on: February 17, 2017, 11:33:56 AM »
Alright so I do have a serious question for all you fellas...  For those of you who have taken a motor down this far, Did you replace any of the bearings on the main shaft/counter shaft? Or did you just inspect them, clean them a little bit and slap them back in?
Basically, i had a tough time getting to one of the counter shaft bearings (in the middle of the case), I didn't want to damage anything so Nils removed it with a bearing puller. He recommended getting a new one, which got me thinking...Should I be replacing those ? That's the only part of the engine that i haven't really thought about....
All the other parts that are going back in have been inspected and are perfect, And are these things still available?
Probably pretty expensive if so. But let me know for those of you that have done this.... THanks
1978 CB750K
2005 Sportster 1208
Offline BLAC
  • An espresso is a
« Reply #171 on: February 17, 2017, 11:48:59 AM »
I don't know about the 750's but they were not expensive and I did buy new ones for my 550.
The stock ones seemed fine, but for the $20 or so I figured what the hell.
Offline Davez134
« Reply #172 on: February 17, 2017, 12:00:29 PM »
I reused mine as they seemed in perfect condition as far as I could tell. As stated its cheap enough insurance to replace them, but I personally did not have a need to.
« Reply #173 on: February 17, 2017, 12:04:59 PM »
Im debating this myself on a race motor I am doing. I am taking the slow burn on getting it done so I will probably do them, but I wans't originally planning on it. The full set for the 750 is almost $250 from CMSNL. One bearing is like $65 so its hard for me to swallow but in the grand scheme you probably won't even notice the money is gone.
Generally speaking for bearings, I have gathered that if they don't "click" when you spin them and they don't have excessive side play, you are good. Flush them out good and give this a spin in a quiet area and listen, if it sounds good, it probably is.
« Reply #174 on: February 17, 2017, 02:11:48 PM »
I reused mine, too.  With a 650 motor they are less readily available.
