Thanks for the help fella's, I really appreciate it. I'll be sure to talk to him about it when it gets done. Trying to remove a stubborn kickstarter (retaining pin?) and definitely looks like something you do not want to break... Done some research so that is where i'm currently at. Need to remove the kickstarter and the shifter cam "detent roller" and then these babies are going on a journey to the West coast, going to get some carbs done and maybe the some side covers too....we'll see but the cases are 100% going.
Good news, talked to Devin at cognito moto on Friday...The last piece of the front end puzzle is coming back from anodizing either today (Monday) or Tomorrow!!!! Once that package arrives I will have literally every single piece to put the GSXR front end together, Top and bottom Triples (50mm offset) , cognito stem with new bearings, Cognito hub (with new bearings and spacers) laced up with Stainless spokes to a non-dimpled Excel rim 18" x 2.5", brand new stainless brake lines, switches, grips..... They even drilled and tapped a hole on the underside of the top triple for my KOSO speedo/tach combo.....
Thanks to Don, I have a beautiful set of GSXR Forks, calipers, and some way cool Galfer wave rotors. I'm hoping this puppy will stop and handle like it's on rails....
I will continue to post updates on this also, once I get the cases done it's going to be time to really get cranking on getting this motor back together...A HUGE THANK YOU to all the guys who have helped me so far along the way....couldn't have gotten anywhere near this far without all you...I really appreciate it. Take care guys. Hope all is well
