Author Topic: No power??  (Read 360 times)
Offline Aaronlee
No power??
« on: July 14, 2016, 06:39:42 PM »
Just replaced the contact points and cleaned jets on my 1975 cb750 mostly stock. It ran okay before but now when I give it throttle I get no power. It's like it gets to a certain speed and that's it. It will shift sounds ok no back firing. No miss firing. Any ideas
Offline b52bombardier1
Re: No power??
« Reply #1 on: July 14, 2016, 06:43:54 PM »
Give it just a dab of choke - a little bit - when it does this and see if it runs better.  If it does, you have a dirty carb - main jet or emulsion tube.
  Recheck your points gap.
Rick
1971 School Bus Yellow Aermacchi H-D Sprint 350
1972 Candy Yellow CL100 K2
1972 Candy Jet Green Honda CB500
1973 Mighty Green ST90 K0
1974 Mars Orange CT90 K5
1975 Topaz Orange ST90 K2
1976 Shiny Orange CT90
2006 Honda Foreman 500 (restored)
Re: No power??
« Reply #2 on: July 14, 2016, 06:50:18 PM »
 If you worked on points and condensers or fiddled with the carbs make sure it firing on all four cylinders. Wet rag touched on hot head pipes should make a good sizzle in a short run time.  Is the timing spot on after working on the points ?
« Last Edit: July 14, 2016, 06:56:38 PM by ekpent »
Offline Aaronlee
Re: No power??
« Reply #3 on: July 14, 2016, 06:51:13 PM »
It only does this when I'm riding. I just tried to give it a little choke when it does it and that doesn't help any. Thank you tho
Offline Aaronlee
Re: No power??
« Reply #4 on: July 14, 2016, 06:54:13 PM »
Just grabbed the pipes they're wrapped lol the two outside ones are really hot. The two middle ones are not I can hold on to them for longer then the outside ones.
Re: No power??
« Reply #5 on: July 14, 2016, 06:58:42 PM »
 May not be firing correctly on 2 and 3. One set of points does 1-4 the other 2-3 but you probably know that. If you worked on those be sure to check your timing also.
Offline Aaronlee
Re: No power??
« Reply #6 on: July 14, 2016, 08:06:20 PM »
Thanks ekpent it was the 2-3 points.. You guys on this forum are awesome  8)
