Author Topic: Caliper and Fork Compatibility (CB750)??  (Read 3092 times)
nickbee
« on: May 31, 2005, 06:51:27 AM »
Will a Caliper from a K2 work with a Fork from a K4/K5?  I’m gathering parts for a café café racer and just want to check on compatibility.
Was there a difference in the calipers over the years?  Any preference I should have if I’m starting from scratch?
Thanks!
Offline Clyde
Re: Caliper and Fork Compatibility (CB750)??
« Reply #1 on: June 03, 2005, 12:35:19 AM »
The same caliper was used from K0 to K6. But the hanger/arm that the caliper bolts to ,was changed from the K3 on.
This means the lower fork legs and front fender mounting points are different.
A different caliper was used for the F/F1/K7/K8. The F1 caliper and arm can be used on the K3 to K6 fork legs, but you must use both together. The F1 caliper cannot be used with either a K0-K2 arm or a K3-K6 arm.
If I was starting from scratch and using a single disc, I would use an F1 caliper/arm on the K4/5 fork as they have a bigger piston diameter and you get a bit more mechanical advantage. If you are using dual discs, probably does not matter too much in my opinion
As Terry would say use an F2 front end and get really good brakes
SOHC4 #1909
Honda CB750 K0(original and unrestored), K1(in pieces), K2(restored), F1(restored), 76 750a (awaiting restoration), 1966 Honda CB72
Suzuki GT750 1972 (restored), Kawasaki Z1 1973 (restored)
laminarflowone
« Reply #2 on: August 15, 2010, 12:23:41 PM »
Not to revive zombie threads, but does that mean I could use a K7 caliper and mount on my K6?  Or is it better to bet a K3 caliper and buy the K6 mount?
« Reply #3 on: August 15, 2010, 01:29:19 PM »
K7 caliper and mount will fit on but looks different..no fins & more. So it works, but you would not want to add it as a second caliper on a stock K6 fork.
laminarflowone
« Reply #4 on: August 15, 2010, 01:43:37 PM »
Thanks, so that would be the same for '78 calipers?  I'm not running dual setup, I just want to have a front brake because mine was missing when I got it from the PO.
« Reply #5 on: August 15, 2010, 04:14:22 PM »
77/78K calipers are the same
 78 Master cylinder though, had brake switch as part of it, as opposed to on lower tree.
