Author Topic: what is this part,where does it mount.1980 650  (Read 1595 times)
Offline crusierlover
« on: July 17, 2016, 05:51:32 PM »
trying to reconnect everything.this exits on the right side,more kind of around the battery box
Offline 05c50
  • 05c50
    • Classic Motorcycle Solution
Re: what is this part,where does it mount.1980 650
« Reply #1 on: July 17, 2016, 06:28:44 PM »
Looks like the ignition module (CDI). There should be two of them mounted under the seat, to the rear of the battery.
http://www.partzilla.com/parts/search/Honda/Motorcycle/1980/CB650+A/RIGHT+SIDE+COVER+%2B+BATTERY/parts.html
.........Paul
« Reply #2 on: July 17, 2016, 09:25:03 PM »
Correct.  If they crap out on you, you can get replacements at Rick's.
http://ricksmotorsportelectrics.com/part/15-101/ODBIb25DQjY1MA==
« Reply #3 on: July 17, 2016, 09:52:47 PM »
thanks.I have 4 of them,hopefully 2 of them will work.if not 124 each means its ebay part sell time.I only have 250 in the bike,not going to spend another 250 for 2 small parts.I have the itch for a 750 anyway.Only problem is I can only find dohc.Better than nothing I guess.I hate shim and bucket valve adjustment.
Offline rb550four
« Reply #5 on: July 18, 2016, 05:34:45 PM »
 Cdi boxes.... yes 2 of them.... isolated mounting.....check the backsides, not the metallic side, wires are encased in a plastic like substance...should be smooth, if it looks a little melted...ain't no good, can't be fixed.
« Reply #6 on: July 18, 2016, 05:40:34 PM »
I got them put back where they belong.No melty stuff.thanks.
