Author Topic: New Front End Stuttering  (Read 982 times)
Offline gwallis
  • 1976 Honda CB550F 1973 Honda CB750
« on: July 17, 2016, 06:21:08 PM »
I just put new front tubes on a recently purchased 1973 CB750.  I got the fork tubes from Cycle X.  They came with new springs and spacers for pre-loading.
This front end is realtively simple in design and not hard to work on.  However, after I got every thing together I get a stutter ( or shudder) when I engage the front brake and push down on the front forks.  The front tire literally shimmy's from side to side.... not a lot but certainly noticable.
Any idea what I did wrong?  It should be noted that the front brake is not completely bled at this time.
Any help would be greatly appreciated!
Offline 540nova
Re: New Front End Stuttering
« Reply #1 on: July 18, 2016, 05:07:30 AM »
Give your new fork tubes a light wipe down with automatic transmission fluid or some other light oil. I think your new seals against new tubes are showing friction. See if this helps. We wipe down the chrome struts on aircraft for the same reason.
Offline grcamna2
« Reply #2 on: July 18, 2016, 05:49:33 AM »
subscribed
Offline Tews19
  • I am no
« Reply #3 on: July 23, 2016, 05:18:53 PM »
Bleed the brake line. Sounds like the pad is hanging up on the rotor. Any pics of how it looks with the new tubes?
1970 Honda CB750 survivor.
