Author Topic: Transistorized ignition, points style. First ones are ready!  (Read 97311 times)
Re: Transistorized ignition, points style. First ones are ready!
« Reply #375 on: May 08, 2007, 09:31:21 PM »
Are you close to Terry and SteveK0?
Well, not in the biblical sense Mark, ha ha! Steve K0 and I both live in Melbourne and Charlie lives in Sydney, but if you want to send them all to me I'm happy to distribute them. ;D
OK, I'll take that...I'm trying to get a cost from thePost Office, then send about 5 of them to you for everyone there.
How's your K2 coming along? Is it running yet? I ordered the PC boards to build that gold one for you (but you can't have it until you test my other one, Mom said so..).   :D
« Reply #376 on: May 11, 2007, 01:34:23 AM »
G'Day Mark, no worries mate, I might install your test ignition on the K0 rather than the K1, as I've pushed everything back to concentrate on enjoying the old beast for awhile before I start any serious restoration.
It's currently fitted with Dyna 5 Ohm coils, should I use these, or would you prefer I fit the 3 Ohm items off the K1? Cheers, Terry. ;D
« Reply #377 on: May 11, 2007, 07:10:32 PM »
You can use those 5-ohm units, but the unit was really designed to test with the Dyna 3 ohm ones. You can decide, though...  ::)
Offline clarkjh
  • Expert? If only.
  • Surely and Samson are now Co-habitating
« Reply #378 on: May 12, 2007, 03:53:51 AM »
Will these units work with CB650 3ohm coils?  I picked up a set because they had replaceable wires.  The wires on my 74 550 are just about done in.
James
SOHC/4 #3328
SOHC/4 Gallery: http://www.sohc4.us/gallery/v/members/personal/clarkjh/
1974 CB550, 40000 Miles
1980 GL1100, 102789 KM - Back on the road after a complete engine rebuild.
*** Why, oh why, is it always head gaskets with me?***
Offline edbikerii
    • Gallery
« Reply #379 on: May 12, 2007, 04:08:52 AM »
Warning to you:  3 Ohm coils on a CB550 will really tax the charging system.  I had to go back to 5 Ohm coils on mine.
James
SOHC4 #289
1977 CB550K - SOLD
1997 YAMAHA XJ600S - SOLD
1986 GL1200I - SOLD
2004 BMW R1150R
« Reply #380 on: May 12, 2007, 11:37:45 AM »
James
James
Edbiker might have a point: be sure to clean your battery cable where it bolts to the engine (remove it and clean it thoroughly) while doing the 3-ohm coils bit. This will improve the otherwise marginal 500/550 charging system a little. The ignition adds a 0.2 amp load into the system, too (not much). If you have a halogen headlight, you can also swith to a little lower wattage unit, like 50/55w or 45/55w. That will also help.
Offline clarkjh
  • Expert? If only.
« Reply #381 on: May 13, 2007, 04:40:29 AM »
Just replaced all the battery connections and wires, also did the relay for the head light.  The wiring harness connections have also been cleaned.  I will probably be putting the fairing and bags back on and will be switching these blinkers and clearance light to LEDs
James
SOHC/4 #3328
Offline milunchbox
« Reply #382 on: February 14, 2011, 09:16:39 PM »
so can you make one with a rev limiter? if so how much?
« Reply #383 on: February 15, 2011, 03:06:13 PM »
Well, a rev limiter is a little out of the scope of this gadget: that feature would require about twice as much componentry. Someday, maybe, but if I do, it would be with inductive pickups that replace the points so the timing can be manipulated electronically. This box is intended to improve the existing system and reduce maintenance while providing a built-in, on-the-road backup system: it's almost a byproduct that it also improves the spark at the plugs.  ;)
