Thanks, spuds. A mix of joy and anguish...
Clearing out the innards now. Pistons are out. Here they are from 1 to 4 (rider side left to right):
![](https://uploads.tapatalk-cdn.com/20180722/6b08fe1ca7a66a12e07e4eda16f215fa.jpg)
![](https://uploads.tapatalk-cdn.com/20180722/6ea69c1d299b4a63bdceb952d6b91d37.jpg)
![](https://uploads.tapatalk-cdn.com/20180722/1af133133d996fc6325f4b478deb697a.jpg)
![](https://uploads.tapatalk-cdn.com/20180722/aa3c45940c91dfe5e2f5f9805f95169f.jpg)
I do like my marshmallows toasty, btw.
One of the rings on #3 had broken off probably as a result of me flipping the engine over (on a padded floor) to get to the bottom engine bolts. I’m wondering if maybe the ring had broken off by my sloppiness or if it had busted off while riding. The cylinders so far upon initial inspection look smooth and scratch-free. Hmmm.
Hard carbon deposits all over the place. Even some hard rock-like deposits on top of the pistons. Gonna give these a gentle bath in some Dawn soap and warm water overnight and a plastic brush scrub tomorrow mid morning. Ease it all into an ultrasonic bath maybe late tomorrow. Treating this engine like an onion and working and cleaning it in layers. I’ll even try to get some soda blast time in.
![](https://uploads.tapatalk-cdn.com/20180722/f05a0417962c03ac768e7a57aff19e03.jpg)
The cam chain and respective parts were suspect of some damage and there was some shearing of the engine case... Should I be concerned or is this negligible:
![](https://uploads.tapatalk-cdn.com/20180722/cc8c3651f7c37ea9fc9cb4b6b0be83e2.jpg)
I was also able to pull out the Push Bar (#7 in drawing) and inner+outer tensioner springs. Not sure if I was supposed to do that as it was a bit of a struggle to do.
![](https://uploads.tapatalk-cdn.com/20180722/4b78e4cf0e258f9c8c0e3593619cc70b.jpg)
The Tensioner Slipper and Cam Chain Guide have probably seen better times.
![](https://uploads.tapatalk-cdn.com/20180722/a2783772d6c8d9878d277b3b30be0f92.jpg)
I’m looking into replacing the cam chain tensioner system with those parts from TTR400, if they even still make ‘em. Or, can I simply clean up the parts I got and possibly replace the tensioner slipper and guide and chain and be good to go?
