Author Topic: IDK Numero Dos - 1975 Honda CB400F  (Read 66236 times)
Offline MoMo
  • Ride like you're invisible
Re: IDK Numero Dos - 1975 Honda CB400F
« Reply #400 on: December 24, 2018, 08:10:28 AM »
He is referencing the shift forks, a case splitter
Offline minimo
  • 1977 CB550F 1975 CB400F 1959 Ducati 200 Americano
« Reply #401 on: December 24, 2018, 08:33:16 AM »
Daaaahhhh.
I loathe dealing with oil. Well, no wasting time then. Gonna go out for a brisk ride to warm up the bike and drain this puppy. Will inspect these “dogs”
Offline minimo
« Reply #402 on: December 24, 2018, 11:48:31 AM »
Version 5.2.0 pending updates
Offline minimo
« Reply #403 on: December 25, 2018, 10:58:22 AM »
Well, this is becoming a real journey into absurdity...
Secondary drive bolt head wanted to have a peek of my garage during a carb sync. I’m lucky this didn’t happen while I was on the road. Anyone ever see this happen before?
Offline strynboen
    • http://forums.sohc4.net/index.php?PHPSESSID=hn418er3dqlmknjj55b3t84os2&/topic,60973.0.html
« Reply #404 on: December 25, 2018, 12:48:34 PM »
Loose bolt on the sekundery shaft.(or is it the primar shaft)....eating the cover...had one before...just weld the hole--and teight the bolt...and get a new Lock plate behind the bolt..as i renember..long time been there
« Last Edit: December 26, 2018, 04:10:52 AM by strynboen »
i hate all this v-w.... vords
Offline minimo
« Reply #405 on: December 25, 2018, 12:51:35 PM »
Loose bolt on the sekundery shaft..eating the cover...had one before...just weld the hole--and teight the bolt...and get a new Lock plate behind the bolt..as i renember..long time been there
Thanks, strynboen. Yeah, I must not have tightened that bolt down. Damnit.
This is the assembly that has that one thick washer that has imprinted “OUTSIDE” on it, I believe.
Meanwhile, looking fwd to inspecting the shift fork dogs. Forthcoming...
I am going to conquer this bike!
Offline minimo
« Reply #406 on: December 26, 2018, 11:32:37 PM »
Always tighten down your hardware
Secondary drive gear, corresponding bolt, “OUT SIDE”-labeled washer, and clutch basket and all surroundings so far look unscathed and fine considering the damage.
I’m going to see about getting this cover repaired
Maybe too far gone?
Offline minimo
« Reply #407 on: December 27, 2018, 12:01:41 AM »
And yes, it is labeled as the Secondary Gear on the Primary Shaft.
I’ll need your eyes to inspect the dogs on my shifter forks, when I can get to them.
Offline minimo
« Reply #408 on: January 10, 2019, 08:53:46 PM »
So, WHAT IF somehow one of the 20mm thrust washers was missing from the gear assembly, say the one on the outer side of the COUNTERSHAFT LOW GEAR COMP, part number 253 pictures here:
Now, this would be a just a hunch but would not having this washer make 1st gear not work so great?
Offline minimo
« Reply #409 on: January 19, 2019, 08:24:40 AM »
Bike is back together and rolling around like thunder. I’ll confirm that it was the thrust washer (or lack thereof) that was giving me those issues with first gear clunking. Not having it there was enough to give it slop and allow it to knick some other gear that it’s not intended to, I guess. The golden rule: make sure these engine parts are accounted for and also be sure to tighten down everything. Luckily, there was no great damage to my shift forks, only some scuff marks. Measured the dogs and for straightness and all seemed within spec. Shifting now with the thrust washer in place sandwiching that top gear makes it all smooth-smooth-smooth. Funny that I’m still kinda cautious getting into 1st gear - real 1st gear trauma.
Other than some light tweaking around, air fuel mix screw adjustments, and a carb synch, I’m pretty pleased with the bike for the moment. Maybe soon I’ll paint the tank and get the seat upholstered.
Offline minimo
« Reply #410 on: January 19, 2019, 08:29:28 AM »
Oh, and a friend made an attempt to weld that clutch cover but there were some pin holes that let fluid through so rather than smothering a bunch of Hondabond all over the inside to seal it I just opted for a replacement part and all is well.
Offline minimo
« Reply #411 on: May 29, 2019, 01:20:29 PM »
I purchased and stuck on that special center stand from AGAIN - it has a cutout to dodge the muffler. Fit like it was meant to be there. Love it.
https://japan.webike.net/products/21955641.html
Meanwhile, bike is running a little crap at the moment - just getting back to riding after some months of being away. Blubbery at high RPM and bike bogs down after riding some duration at speeds of up to 75mph. It’s the carbs.
Just finished a carb rebuild replacing the aftermarket needles and emulsion tubes back to OEM to see if that might make it right. Also downsized the jets from 90 to 85 (75 is stock) and maintained the needle clip at 4th from the top (3rd from top is stock) - a recommendation from harisuluv (is he still around rebuilding carbs and making seat hoops?) and he said “works quite well”. Pilot jet is 40 stock. See how this set up goes in the AM.
Next day after this rebuild:
So far so good - the best this bike has been running in a long time. Testing the rides out on surface and seems steady so far. Will take to highway for a more longer and faster ride.
This is what I’ve been missing - chasing issues is what the fun is mostly about
Offline strynboen
« Reply #412 on: May 29, 2019, 01:32:38 PM »
its  fun ...as long the bike gets better.
..one step forvard...and 2 back..can kill the road fun.
.but seems you have get over the vorst problems..and just need fine tuning now...
need to find a battery for my 400..it have not be driven this seson...so have lost all power..just like mee...hope to get a few road  rides this summer..the 550 stays ready..its the most relibel bike..can stay for monbths,,and fires just up..and is ready..
Offline minimo
« Reply #413 on: May 29, 2019, 01:34:43 PM »
These bikes are just like us, strynboen. I agree!
Let’s get some great rides in this summer!
Offline Rick4004
« Reply #414 on: May 30, 2019, 02:29:08 PM »
You are probably too rich all thru the rev range. The 400's run better with 38 pilots when using pod filters, and I've never had to change the needles from the stock position. 85 or 90 is probably about right for the mains. I haven't read your build, but aftermarket coils make a big difference too. The stock coils are crap.
Offline minimo
« Reply #415 on: June 09, 2019, 05:58:03 PM »
Keepin it cool and hearty
Offline minimo
« Reply #416 on: November 25, 2019, 06:15:09 PM »
Well, while I had the cases split apart again, I figured I’d replace some “while I’m in there” parts.
Guess which one’s the used primary drive chain?
Offline minimo
« Reply #417 on: December 12, 2021, 01:58:40 PM »
I hope everyone is out enjoying the rides and doing well, keeping warm.
This happened today:
Crusty welds (by a previous owner).
Nearly laid the bike down.
« Last Edit: December 15, 2021, 07:04:35 AM by minimo »
« Reply #418 on: December 12, 2021, 02:05:00 PM »
Minima, that bites…hope you still have a center stand…
Offline desertrefugee
  • Still wanna be a...
  • Phoenix, AZ
« Reply #419 on: December 12, 2021, 02:11:20 PM »
... I hope that doesn't mean the bike hit the ground
'86 Vmax, '83 ZN1300, '78 GL1000, '75 CB750 K5, '78 F4
Offline minimo
« Reply #420 on: December 12, 2021, 02:16:59 PM »
Center stand is intact. I muscled the bike up, so I lucked out.
I got a great center stand from Again (Osaka, Japan). It dodges the header
Offline strynboen
« Reply #421 on: December 15, 2021, 10:57:32 AM »
have sold my 550,,so only have the 400 four..it runs..but need a total rebuild..all thains and crank bearings..need to be thanged..and the camis veared..dirty oil..and 85,000km have done the job
great that you still are on forum...
« Last Edit: December 15, 2021, 10:59:13 AM by strynboen »
Offline minimo
« Reply #422 on: December 17, 2021, 09:14:16 PM »
Looks clean, strynboen.
We’ll, you know that you can access the lower crank case from the bottom. Easy-peasy
Enjoying the rides on my 400. Maybe someday soon I will get the seat upholstered and the tank finally painted. Maybe then I will consider to finally sell the bike.
2022 will be the year that I get moving on a classic Ducati single rebuild. The fun never ends.
Offline minimo
« Reply #423 on: October 03, 2022, 12:21:05 AM »
Offline wolf550
« Reply #424 on: October 03, 2022, 01:25:53 PM »
that is what I will be doing in the near future with these three carb sets.
going to see what is good on each set and make a good set.
74' CB550 (Sold)
71' CB500/550 (Sold)
