Author Topic: Saddle bags for a 400f ?  (Read 10788 times)
Offline grcamna2
Re: Saddle bags for a 400f ?
« Reply #75 on: August 26, 2016, 08:46:35 PM »
That looks good on there,a nice size luggage 'platform'  8) Have you used it to go get a 'suitcase' of brew yet ?!
Offline thirsty 1
« Reply #76 on: August 26, 2016, 09:01:21 PM »
N fact I have! I use the larger bungee though,  lol ! A nice 12 box fits just right!!
Offline grcamna2
« Reply #77 on: August 27, 2016, 07:15:58 AM »
Were you able to give it a solid 4-point frame mounting? I had the same model/size of CCA rack that I installed on my CB350 and it carried 50lbs. no problem;they are strong.
Offline brewsky
« Reply #78 on: August 29, 2016, 04:57:38 AM »
They are strong to a point, but not beyond...
If you put too much weight on, it will bend just past the rear most mount.
I reinforced this one with a slightly smaller inner bar, and it still bent.
Not sure if it was the 24 packs or the camping gear, but this one used to be straight!
66 CA77
78 550K
78 CB750K
02 FZ1
09 GL 1800
Offline grcamna2
« Reply #79 on: August 29, 2016, 05:49:47 AM »
Oh,
I had my latest one bend also  :D The one I have now is a CCA rack that's 2) mount bars are mfg. in a type of 'S' bend.I got the rack real cheap at Barber's a few yrs. ago and it had been sitting outside a long time in the rain upright so the water sat inside it for yrs. and thinned the steel.I found out later while on a long trip when hitting lots of bumps w/ weight on it,that it was bending.I had a welder install a few gussets and that fixed it and now it's stronger to carry good weight.
Offline thirsty 1
« Reply #80 on: August 29, 2016, 07:16:42 PM »
Yes I can see how this could happen. I instructions say 30 #'s max and I can see why this is recommended. I gathered that as long as some sort of prejudice is used it should, and will, hold up just fine. :)
