SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
SOHC/4 Shop
Home
Help
Login
Register
Donate
Tech Forums
SOHC/4 Bikes
Topic:
Which direction for fork seals?
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Which direction for fork seals? (Read 3387 times)
SKOL
Hot Shot
on:
July 25, 2016, 02:33:19 PM »
Reassembling my front forks, can't remember which direction the fork seal faces. One side Is double lipped, the other flat. I'm assuming the flat side goes "down" toward the lower fork assembly but just wanted to check. Below is a picture of the double lipped side, I'm guessing this double lipped side faces "up".
Logged
scottly
Global Moderator
Really Old Timer ...
Humboldt, AZ
Re: Which direction for fork seals?
Reply #1 on:
July 25, 2016, 02:40:07 PM »
The flat side with the numbers goes up, and the double lipped side goes down.
Logged
SKOL
Hot Shot
Reply #2 on:
July 25, 2016, 02:51:54 PM »
Well both answers so far are opposite haha
Logged
scottly
Global Moderator
Humboldt, AZ
Reply #3 on:
July 25, 2016, 03:28:02 PM »
And only one of the answers is correct.
Logged
Stev-o
Ain't no
Central Texas
Reply #4 on:
July 25, 2016, 05:19:05 PM »
Text/numbers up!
Logged
Johnie
Reply #5 on:
July 25, 2016, 06:03:23 PM »
OEM seals? If so, like Stevo said text/writing goes up.
Logged
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI USA
scottly
Global Moderator
Humboldt, AZ
Reply #6 on:
July 25, 2016, 06:13:46 PM »
OEM or aftermarket, the text/numbers go up. I just got some aftermarket fork seals, and they are double-lipped on both sides! I've never seen seals like this before! The instructions say the text goes up, but it's very small as it's on the edge of the thin outer lip.
Logged
przjohn
Expert
Reply #7 on:
July 25, 2016, 06:24:21 PM »
Open end with the spring showing goes down facing the inside of the fork. Normally a seal will be set with the open end showing the spring toward the liquid it is sealing in, think shift seal, k/start seal, crank seal, etc.
Logged
SKOL
Hot Shot
Reply #8 on:
July 25, 2016, 06:45:10 PM »
Thanks guys! Got the seals in with letters/numbers "up" and everything else in and buttoned up without a hitch!
Logged
Mr Freeze
Hot Shot
Reply #9 on:
July 25, 2016, 07:53:25 PM »
Sorry I messed up. My wording was supposed to be the side you're holding up goes in first.
Logged
Johnie
Reply #10 on:
July 26, 2016, 05:14:54 AM »
Glad you got it sorted...
Logged
Oshkosh, WI USA
Print
Pages: [
1
Go Up
« previous
next »
Tech Forums
SOHC/4 Bikes
Topic:
