Author Topic: Leaking Float Bowl Gaskets  (Read 354 times)
Offline OCW85
« on: July 26, 2016, 07:28:35 AM »
I recently cleaned my carbs on my cb400f and and put everything back in the correctl order. The float bowl gaskets were flattened and sticking to the channels so as carefully ad I could, I "peeled" out the old gaskets and cleaned the channels with a brass brush and small metal pick to get the pieces the were still sticking. I used the pick very sparingly and with as little force as possible.
I purchased new gaskets from 4into1 (pretty sure they aren't OEM) but they are in the "home base" shape on the bowl. That said, they were a hair small, so with some very minor stretching and some light grease to hold them in place, I installed the float bowls.
I reinstalled the carbs, turned on the gas, and BAM - all 4 start leaking from the BOWL GASKETS and NOT the overflow tubes. I took them back off, double checked the float height (21mm), cleaned the valve and valve seat, reinstalled them and got the same result.
I have not tried the clear tube test, but I did lightly hit the bowls in case of stuck floats, but that did not help.
On further eval, the o-ring around the brass valve seat looks pretty flat, which leads me to think gas is getting past the valve when cloased.
What I find odd is all 4 leak from the same spot and they are NOT leaking from the overflow tubes. When I first got the bike they leaked a bit from the tubes but not the bowl gaskets. Did I mess rhe gaskets up but stretching them a little? Also, what are the odds all 4 need the valve seat o-ring?
Any help would be GREATLY appreciated!
