Author Topic: '70 CB750 carb dilema  (Read 1205 times)
Offline major domo
« on: July 26, 2016, 12:57:14 PM »
The carbs on my 1970 CB 750 are missing the caps (screws?)  that cover the carb sync port where carb vacumn gauges attach. There is no part # listing for these, and a major supplier of NOS Honda parts says they are NLA. Anyone out there have a set (4 needed), or can reccomend a substitute? Photo attached for reference. Thanks in advance!
Re: '70 CB750 carb dilema
« Reply #1 on: July 26, 2016, 01:17:25 PM »
IIRC, they are M5x0.8mm x 6mm
Bolt depot has some standard and socket screws that would work unless you are looking for used OEM stuff.
https://www.boltdepot.com/Product-Details.aspx?product=15644
Im sure I have a set in a bin somewhere if you prefer.
Offline Johnie
« Reply #2 on: July 26, 2016, 02:10:46 PM »
Keep in mind there is a thin washer on those 4 sync screws too. They actually look like a crush washer as you sure don't want a vacuum leak at those screws.
« Last Edit: July 26, 2016, 02:12:45 PM by Johnie »
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
« Reply #3 on: July 26, 2016, 02:20:14 PM »
Isnt it paper or fabric of some sort?
Offline harisuluv
« Reply #4 on: July 26, 2016, 02:23:36 PM »
It's an aluminum crush washer.  The only fabric type washer on the carbs is the red one on the float valves.
The aluminum crush washer applies to the brass type sync port screw, but I have also seen K0 carbs that come with an aluminum sync port screw, similar to those on the 77-78 PD carbs sans the crush washer.
« Reply #5 on: July 26, 2016, 03:53:49 PM »
I think brass screws are till 76 and PD uses alloy..
