Author Topic: M-unit turn signal issue.  (Read 3189 times)
Offline Gizmo
« on: July 26, 2016, 09:24:38 PM »
Hey guys. I am in the process of wiring a new harness for my bike with an M-unit and M button. The issue i am having is that when i select a left turn everything works fine, but when i slide the switch to the neutral position the lights continue to blink. If i move the switch for a right turn, the lights come on, but as with the left side will not stop when i move the switch to the neutral position. The only way i can cancel the lights is to momentarily switch the turn signal switch to the affected side and then off again quickly.
Am i missing something obvious? or is this something i need to program in the config settings? ( i know the m-unit has an auto off function that should cancel the turn lights after a set period of time, perhaps this is where my problem lies?)
Thanks for any light you can shed on this for me!!
Offline Cqyqte
Re: M-unit turn signal issue.
« Reply #1 on: July 27, 2016, 05:02:58 AM »
Does the M unit require the use of momentary switches?  Sounds like that could be your problem.  Most metric switches are N.O./N.C. center off style.  If the M unit requires momentary switches it will see a metric switch as constantly applying a single, instead of a single pulse.  Just a thought.
Offline sinister902
    • Anger Street Kustoms
« Reply #2 on: July 27, 2016, 05:12:06 AM »
M unit does in fact use momentary.
Offline Jimbo
« Reply #3 on: July 27, 2016, 05:34:11 AM »
I had this issue also when I was wiring in my handlebar controls on my cb400f. The way I fixed this was to go into the m unit settings and change the handlebar control section.
If you've never owned one you'll never understand
CB400F
"If you've never owned one you'll never understand"
CB400F
Offline Cqyqte
« Reply #4 on: July 27, 2016, 05:54:14 AM »
7.6 Handle Bar Controls
Three different types of handle bar controls are compatible with m-Unit. The particular type which
will be used with m-unit must set in the setup menu.
Configuration A) – Push Button Controls
- turn lights left - push button
- turn lights right - push button
- low beam / high beam - push button
- start - push button
- horn - push button
Configuration B) – Harley Davidson and BMW controls
- turn light right - push button
- low beam / high beam - switch
Configuration C) – most Japanese and European motorcycles
- turn lights left / right - 3 way switch
configuration D) – new Ducati models
In case of using the OEM handle bar controls together with m-Unit; head light flashing push button
is not applicable. There is also no possibility to switch the parking light by the m-Unit.
Offline Gizmo
« Reply #5 on: July 27, 2016, 09:31:16 AM »
Thanks guys! i will go buy a small switch today to cycle through the setup options.
Offline Gizmo
« Reply #6 on: July 27, 2016, 09:30:31 PM »
Worked like a charm! it took awhile to get the timing right to access the programming menu but once i was in everything went according to plan. Thanks for the assistance!
