Author Topic: Anybody welded to an old shifter lever ?  (Read 1105 times)
Offline greenjeans
  • 1972 CB750K2
« on: July 28, 2016, 09:24:26 AM »
Cast stock shifter lever...  Anybody welded to one of those before ?
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
Re: Anybody welded to an old shifter lever ?
« Reply #1 on: July 28, 2016, 10:54:31 AM »
Seen it done once or twice.  Mostly in the offroad scene.
« Reply #2 on: July 28, 2016, 11:21:29 AM »
Not cast, that is why they get bent.
Offline greenjeans
  • 1972 CB750K2
« Reply #3 on: July 28, 2016, 11:55:47 AM »
Sweet - thought they were cast.    I'm making some rearsets but want to use all the old Honda stuff instead of the newer billet sets.
Offline strynboen
    • http://forums.sohc4.net/index.php?PHPSESSID=ehceoubp97lnfrvtassbd0o8u7&/topic,60973.0.html
« Reply #4 on: July 28, 2016, 12:55:49 PM »
kick shafts is hardent,,and can not be veldet..so it holds.
.gear shifter shafts, is soft steel..so you can veld a used splined end on..i have done it tvice..and it holds up nice..i had used some Yamaha fs1 parts..they all  looks to be universel in the splined end.. have use both Honda china kopi and Yamaha pedals on my cb 550/cb 500 twin
i had drilled a senter hole in the one part..and turnde a tap.on the caunter part,,to align them perfekt up..if it are the arm  or pedal or link arm..its also soft steel..so easy to veld and machine to fit
klick on Photo to get it bigger
« Last Edit: July 28, 2016, 01:03:25 PM by strynboen »
i hate all this v-w.... vords
« Reply #5 on: July 28, 2016, 03:08:44 PM »
anything special need to be done with the chrome to make this happen?
Offline MiGhost
  • What was that about being an
« Reply #6 on: July 29, 2016, 01:37:09 AM »
It should burn through the chrome, but you could grind it away if your so inclined.
I have a heel-toe shifter that was obviously not ground clean. Just minor rust showing in the weld. got to clean and power it eventually.
~Ghost
~ Ghost
Grey Ghost '80 CB650C: Updated Stock Restomod. Period Custom Cruiser (OEM harbags & trunk, Wixom Ranger fairing, Jardine turnouts)
Bad Moon '83 XJ750MK Midnight Maxim: Full Dress Tour Deluxe w/ X-1 Fairing
