Author Topic: Float pin  (Read 592 times)
Offline Ereyer
Float pin
« on: July 30, 2016, 11:29:20 AM »
Hello all:
Just wondering if there is a suitable replacement part for the brass pin/dowel that holds the float onto the carb? Mine, of course, broke as it was sealed on the housing after many dirty months.
Thank you in advance!
Eric
Re: Float pin
« Reply #1 on: July 30, 2016, 12:06:42 PM »
Mike it , if its nominal. Size,  hobby shop may have something, or cut down a drill bit..probably. Be a number, letter or metric drill...easy...
Offline Ereyer
Re: Float pin
« Reply #2 on: July 30, 2016, 12:16:48 PM »
I think I got it. I straightened a wall hanging screw and cut off the threads. Pretty much the same length and the same material (brass).
Eric
